I think one of my ABS hubs are damaged and when I push the accelerator to the floor and then try to stand on the brakes the car just keeps accelerating.
It will not do this if I do the reverse and if I brake normal (without my foot on the accelerator) then the ABS works normal.
If there is a fault with the ABS you will have the ABS warning light on - if not then your ABS is OK. Accelerator and brakes on at the same time is generally only used to check the stall speed of the torque converter - do it for more than 5 seconds and you cook the oil and can/will damage the converter - engine revs should not go higher than whatever stall speed your converter is - my old Jag was 1900rpm...not sure with a Commo.
Yes, Accelerator pedal and then the brake pedal, in that order, at the same time.
If I press the brake pedal and then the accelerator pedal in that order at the same time then everything is normal.
sounds like you have a vacuum problem. when the car is idling the engine produces a high vaccum and this works to assist you (through the brake booster) the brake booster has a one way fitting so that when you accelerate the vacuum is maintained in the brake booster. if the pedal feels really solid when your accelerating (very little engine vacuum) i'd suggest that your one way valve is stuffed.
try the brake pedal with the engine off. then start the engine with your foot on the brake pedal and see what it does. then switch the egine off again ( still with your foot on the pedal) and tell us what the brake pedal does
Body by Holden, Soul by Brock
the Legend will live forever
Pedal sinks then when off then it tries to push back at me a bit.
When I switch the motor back on and drive off there is a small, almost electric motor type noise from under the bonnet/
either your one way valve is stuffed or the booster has a leak.
^ yeah, will get that fixed, as just got worse, pedal rock hard after the motor is stopped now.
Anyone tell me the difference between the IRS and 5 link (solid axle) front hubs?
