Results 1 to 9 of 9
Thread: rattling pulley engine noise when idleing
    VR WGN
    Oct 2007
    Default rattling pulley engine noise when idleing
    Hi I have a rattling noise coming from the front of the engine on my VR it's done 240k
    I first thought it was the belt tensioner pulley so I replaced that and the noise was still there, when I turned on the air con the noise got louder and worse so I then I bought a shorter fan belt to bypass the air con but noise is still there. When I take the fan belt completely off the engine the noise stops.
    I've tried listening with a screw driver and a piece of hose but it's so loud that I cant pin point it.
    The water pump feels firm when I try and move it, the harmonic balancer feels firm but... there are bits of rubber missing out of it ! I did think without the belt on it's not under any load.
    The power steering pulley does have a bit of movement in it.
    Any ideas ? I think it's either the power steering or the harmonic balancer
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Rider5 View Post
    It sounds like the harmonic balancer is the problem, bits of rubber missing from it is not good.
    MY RIDE
    markholland's Avatar
    markholland is offline hotrotor.17
    VS EXECUTIVE V6 sedan & VE SV6 Ute 60th Ann
    Nov 2008
    sydney
    Hi
    Change the AC pulleys they are a common problem There are 2 of them about $15 each easy to replace 15 mm socket to take off they the originals were metal now they are hard plastic.
    [SIGPIC][/SIGPIC]hotrotor.17
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    il put my money on a harmoic balancer too
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by markholland View Post
    Hi -
    He put a shorter belt on by-passing the compressor and the noise was still there.
    MY RIDE
    5 speed VR's Avatar
    5 speed VR is offline Green Machine
    Vr V6 Exc 5 spd
    Apr 2006
    Sunny Coast QLD
    Quote Originally Posted by accentstencil View Post
    I was driving along one day when bang something went in the front and a hell of a noise was comming from the motor, turned out to be the harmonic balancer and there was a big chunk of rubber sitting on top of my battery from the balancer. Got it replaced and no noise.
    When i grow up... i want to be young again
    VR WGN
    Oct 2007
    Thanks guys, I figure it has to be the harmonic balancer and a mate had a look at it he reckons by the way the rubber is cracked with bits missing that it's probably the cause.
    Any recommendations who I can take it too, NOR in Perth ?
    VR WGN
    Oct 2007
    OK Here's my feedback for any one else that may have a similar noise. Yes it was the harmonic balancer. I got a new one put on now she's as quiet a mouse.
    VS CAPRICE
    Dec 2008
    Sunshine
    If it is a V6 . Turn the steering wheel left and right and rattles it head off. Like the other guys said. Harmonic balancer. Check it out the rubbers in it are prob all cracked..........
  1. weird pulley noise coming from front of engine
    By muney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2011, 12:37 PM
  2. VR Commodore - rattling noise from front of engine
    By mar06mir in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2009, 10:38 PM
  3. Engine Light comes on while idleing
    By fitz_vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2009, 04:38 PM
  4. Vibrations under 1000 RPM, rattling noise from engine
    By Steery in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2008, 03:21 PM
  5. rattling noise?
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-04-2005, 10:40 PM
