Results 1 to 8 of 8
Thread: strange noise
    Vs Commodore, Vr Acclaim
    Feb 2009
    Default strange noise
    Hi there, just bought a vr sedan today, great engine and box seems fine, changes well and no slip, but when driving it home for the first time a strange sound happened. It drives fine from take off , even when giving it a bit, but if cruising at 100 and then give it some it made a sound from the back which i can best describe as the same as when you run over those wake up strips on the side of a freeway but a little louder and a little more metallic... it also happens under load like going up a steepish hill. any advise would be helpful, thanks
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by tenggo View Post
    You say from the back of the car so straight away i am thinking diff/suspension but since this was whilst cruising im leaning towards the diff. Is it a single spinner or LSD and do you happen to know when the last oil change was made on the diff?
    Feb 2009
    Hi, thanks for reply. No idea when the last oil change was done on it, i only got it yesterday. It is a single spinner i guess? it is a non irs axle and is an executive... I have been driving around today to test it out a bit and it only makes the noise if i am sitting around 100 (doesnt happen at lower speeds) and put my foot down or going up a hill and trying to maintain 100 it will make the noise too if i back off it goes away. I can accelerate from 0 to 100 , even with foot flat down and in wont make the noise...
    VR Berlina
    May 2009
    Hello There
    Are you still having these issues?
    Because I have the exact same problem!
    I will explain what i have tried and the history of what caused it, If you have fixed it i will make a new thread. Unless you can tell me how you fixed it
    VS RB30E(T)'s Avatar
    VS RB30E(T) is offline Project 'VS3.0'
    Series 1 VS Berlina 3.8L
    May 2009
    I'm another victim of this problem, drives me nuts sometimes but it's not constant. Mine seems more prominent around 70-80 klicks. Let me know how it goes.
    Changa is offline Alex Short
    VS Executive
    Jan 2009
    Hervey Bay, Queensland
    Yeah I have the same problem, I believe it is part of the transmission called the Torque Converter Clutch (TCC). I believe its faulty and isnt locking together properly, although I cant be sure. My mechanic said I would be better off replacing the entire tranny with a reco'd one instead of just replacing the TCC.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the cheap options first - rear engine mount in particular...also 2 front mounts....check exhaust from ex manifold to tailpipe.....centre bearing on the propshaft also the uni joints. A reco trans will cost upwards of $2000 so hope it is not that.
    Good Luck.
    VR Berlina
    May 2009
    Hey Guys,
    I Think there are 2 different issues here, But they are very similar.
    The first one, Is the one thats sounds like your running over (cats eyes) wake up strips.
    I had this problem with my Commy, now it IS a gearbox fault, what i found is it was the Torque converter Skippin or bouncing. To confirm this there is a fault that comes up in the cars PC, "autotheft dect" (or something similar) even thou that sounds completly off topic it actually means that the ignition is causing the torque converter to bounce/skip and the simple fix for this is to change your plugs and get new leads. This resolved the issue for me.
    I know that sounds werid ,but it is definatly the fix for that issue.
    But by leaving this for to long I think I have damaged my gearbox and now im getting a completly different gearbox noise.
    That sounds more like a groan at certain revs over 80-100km.And you can feel it get sluggish whilst it is doing this noise, If you take your foot off the accelerator or drop it down a gear the issue goes away.
    Any ideas for this? Im just assuming im gonna need a new torque convertor or just get a new Gearbox, both these issues involve pain / cash
  1. strange noise?
    By Rg123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2009, 11:48 PM
  2. strange noise NEED HELP!
    By aussie_cruzin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2008, 04:05 AM
  3. Strange noise
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2008, 12:14 AM
  4. VZ SV6 strange noise
    By Haysie in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-04-2008, 08:43 AM
  5. Strange noise!
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-09-2007, 06:08 PM
