Results 1 to 3 of 3
Thread: Wiring Loom?- where?
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    Exclamation Wiring Loom?- where?
    is it the metre long cord running behind the dash that plugs into the BCM???...
    also can i run an Equipe BCM in an executive??......without the extra options??....
    i am planning on running the extra options later, (power windows, etc) but i want to install the BCM now.
    thanks guys
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    the wiring loom is the wire that runs from the engine bay to thru to under the dash, and then down the door sills and into the boot. there are plugs along the loom, but some is one piece thru into the bay.
    yes you can run the equipe BCM in an exec, but u'll have to use the key that cam with the BCM or get a new key and have it coded to the new BCM, otherwise u wont be able to disable the theift deterent signal.
    Feb 2009
    thanks buddy, forgot about the key issue.
  1. need wiring loom help.
    By Haydz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-07-2008, 03:11 PM
  2. Wiring loom Help
    By eko in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-10-2007, 12:41 AM
  3. VS 5.0L Wiring Loom
    By darwinvest in forum Electrical Wiring / Questions
    Last Post: 25-09-2007, 09:00 PM
  4. Wiring Loom Help
    By soulyouth in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2004, 09:41 AM
