Results 1 to 3 of 3
Thread: VR Power Windows. Sorry!..please help
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    Exclamation VR Power Windows. Sorry!..please help
    Hi guys im just sitting in the shed pulling the Power windows out of the Equipe. to put into my Executive Wagon.
    ok my Dilema is is...i have no keys for the Equipe.
    so i guess i cant use the BCM to control the power windows
    Can i get around this some how??? like without using the BCM??
    do i need the whole wiring loom? or just
    Fuse Box, Each doors loom etc?...
    how can i dothis?? thanks alot guys
    P.S the "how-to" isnt very helpful atm
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    The link posted above should be pretty easy for you to follow and also lists the parts required. However because you're sourcing your parts from a vr, you'll need to source a few other bits to complete the install. From the vr equipe take the window regulators, switches, door trims, door wiring looms (you may not end up needing the front ones but take them just in case). Also take the wiring harness that plugs into the front switches. Unless you go pulling the dash apart to get all the wiring you will have to cut this one and join it later so make sure you keep both parts of the plug with enough wire connected to easily join it later. Then, from a vn or vp you will need to source the power window control module. It mounts near the interior fuse panel on the left hand side of the steering column. Hope that helps.
  1. Options..power seats... power windows??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2010, 06:01 PM
  2. vk power windows
    By sarj in forum Electrical Wiring / Questions
    Last Post: 26-03-2008, 06:07 PM
  3. vr power windows
    By The_Fat_Man in forum Electrical Wiring / Questions
    Last Post: 17-04-2007, 03:59 PM
  4. Power windows, off then on !
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-12-2005, 09:43 PM
  5. Power Windows
    By blu 5L ute in forum General
    Last Post: 17-03-2005, 11:22 AM
