Results 1 to 7 of 7
Thread: no spark on a 304
    skweek's Avatar
    skweek is offline vr 355
    vr commodore
    Oct 2006
    albany
    Default no spark on a 304
    hey guys just want to know if there no spark commin out of the coil, what would cause this ??
    when i get sad, i just stop being sad and be awesome...true story!
    VB SL/E
    Dec 2008
    Either no power going into it or a dead coil.
    Is the coil getting power?
    Do you have an ohm meter?
    Primary winding resistance 0.76 - 0.84 ohm
    Secondary winding resistance 4860 - 5940ohm
    skweek's Avatar
    vr commodore
    Oct 2006
    albany
    yeah its hettin power 12v to the pos side. the coil should be alright it worked when the motor was in the other car. what is a ohm meter ? is it like a multi meter
    VB SL/E
    Dec 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also could be faulty ignition module or the hall effect part of the distributor - both fairly common problem items - do a search on this forum and you'll find plenty of references.
    Good Luck.
    skweek's Avatar
    vr commodore
    Oct 2006
    albany
    if the ignition module is fulty the car just wont start?? what about if i have the wrong memcal in the computer, its a vr computer but with a vn memcal??
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if its a VR V6 manual or VR V8 ecu and a VN V8 memcal should go even if it had a V6 memcal it would probably go
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. spark one day gone the next
    By v6lj in forum General
    Last Post: 06-01-2009, 01:21 AM
  3. VK 202 no Spark...........
    By rx98liberty in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-11-2007, 11:04 AM
  4. Spark lead to spark plug order...
    By james_and_his_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2007, 08:33 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
