Results 1 to 5 of 5
Thread: vacuum leak cause hard start?
    Vs Commodore, Vr Acclaim
    Feb 2009
    Default vacuum leak cause hard start?
    Hi there, i have a vr v6 and have error code vacuum leak. Is this in any way related to it being hard to start, will kick over and then seems to be flooded or somethin for the first couple of seconds. i give it a few revs and is fine. Also when driving around and stopping at light etc it will idle with low revs. I have checked as many vacuum lines as i can see but can find the leak...
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Remove the engine cover and carefully check all vacuum lines especially around the throttle body....they usually split where they connect. What was the actual code number?
    Feb 2009
    it is error 36 , i have checked all round the engine, and the ball thing under the guard, is there some lines in the dash? and would that be the cause of the low/rough idle and starting, thanks
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check this post as it may help:
    Vacuum Leak
    Also scroll down the bottom of the current page and check the 'similar threads' - there are a lot of different posts on your problem there. Hope this helps.
    Feb 2009
    cheers thanks
  1. Vacuum Leak?
    By WinterVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2010, 12:39 AM
  2. help with a vacuum leak
    By iillstevellii in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-03-2008, 09:55 AM
  3. Vacuum Leak
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 01:33 PM
  4. Vacuum Leak
    By maginoodle in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-04-2006, 11:27 PM
  5. Vacuum Leak???
    By mazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2005, 02:53 AM
