Results 1 to 7 of 7
Thread: Tailshaft phasing
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Tailshaft phasing
    After i swapped my diff there's a slight whirring noise coming from the rear, now this could very well be an LSD in need of new cones or bearings, but i read in my manual that an out of phase tail shaft could cause whirring.
    Is this something i can fix myself and if so, how? Or is it a professional job?
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you pull the driveshaft in half or something
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by maldotcom2 View Post
    Unbolt the tail shaft, spin it 180 deg and bolt it up again. Might be better, might be worse, might have zero impact. You won't know until you try it. It did fix a vibration I had in my old VP years ago.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    Dec 2008
    Nah i didn't pull it in half. Just disconnected it at the diff obviously. It makes the noise as soon as i touch the accelerator no matter how lightly, but not coasting, does this sound consitent? I'm really just stabbing in the dark here.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    youve probably got a sloppy diff with a knaffed bearing or teeth on the crown wheel and pinion
    Dec 2008
    Might change the bearings then, the pinion and crown looked perfect before i installed it.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If it only does it under load chances are it is gears. A bearing in the diff will make noise no matter what. Are they meshed correctly? If the teeth aren't meshed correctly it will whine.
    Visit my Facebook page
  1. VR Tailshaft Q....
    By holdenboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2008, 11:05 PM
  2. separating tailshaft and tailshaft lengths
    By dans_vz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-03-2008, 08:18 AM
  3. Phasing VP Commodore V6 drive shaft
    By Abe in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2006, 09:53 PM
  4. Looking for a VK 5sp tailshaft
    By shanhsv in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-03-2006, 10:05 PM
  5. Tailshaft
    By AirStrike in forum General
    Last Post: 01-05-2004, 04:31 PM
