How could i put a pod filter on my vs and do without the wire that runs to the original air filter box? I've put a pod filter on my car before and all i got was the engine light non stop until i put the standard set up back in. Can anyone help me so i can have the pod filter on please. Cheers
might grab a drink to listen to the old pod filter argument again
Forecast For Tonight Is Alcohol, Low Standards And Poor Decisions.
haha you need to drill a hole in the plastic intake pipe and mount the airtemp sensor in it thats normally in the airbox.you can mount it in the pod adaptor as well pretty easy.
just buy a cold air intake off of ebay
should be able to get it for around $70-$100 then get a K&N panel filter $90-$100
This will deliver colder air to your engine and will make your engine bay ALOT more tidy =)
other wise drill away ...
i agree mate cold air and hi flo panel for sure. i got a genuine s/c cold air intake and k&n panel filter for $150 posted on ebay![]()
as said ^ , but if your heart is set on a pod filter, u can get adapters for them at autobarn for about $10 last time i checked, but that was awhile ago..might be a bit more now but go look
ive heard of a sensor you can buy that plugs into the wires and it reads the air temp a bit lower apparently the stock sensor reads it higher than what the air temp actually is to save on fuel dont know if its true or not but like ive said ive heard of it and seen it done dont know if its and good or not
