Results 1 to 6 of 6
Thread: normal readings for vs?
    PSYKO PHOENIX's Avatar
    PSYKO PHOENIX is offline AHHHH brain fart
    1995 VS Commodore v6 ecotec
    Nov 2008
    rotorua, NZ
    Default normal readings for vs?
    yay finaly all the gauges are in, so i dont have to anoy you with questions on how to install them!
    however i do want to know, what the normal temps and pressures are
    water- 1/4 - 1/2 the dash gauge (every one knows that)
    oil pressure in BAR: ?
    oil temp: ?
    just so i can see if shes runnin fine or not
    thanks in advance, cheers
    you dont turn a holden off
    you power it down!
    for any one who asks, holdens dont leak oil, there marking there territory
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    1 PSI converts to 0.07 BAR
    At idle a vs v6 should have an oil pressure of 62 PSI and at any engine speed over approximately 2000rpm this increases to 66 PSI. So, using these figures you should have a pressure reading of 4.34 BAR and 4.62 BAR respectively. Im not sure about the oil temp sorry. Hope that helps.
    Nov 2008
    rotorua, NZ
    brilliant mate! thats right were shes sitting!
    thanks heaps for that - im guessing that as the oil warms up the oil pressure is lower, when the oil is hot om the tepm gauge the vs idols at 3 bar
    your a champion, thanks for your help!
    now i just gotta get the oil temps!
    you power it down!
    VX SS M6
    Jun 2005
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i'm interested to see what oil temps your getting. mine takes ages but eventually gets upto 210degrees F (about 100degrees C) i can get it hotter by really giving the loud pedal a workout. i've also noticed once it is upto temp variations in watertemp don't seem to effect the oil temp much (if anything) although i do run a 82degree thermostat so my engine runs cooler then normal.
    my VN with (ecotec oil pressure spring) idles at about 60+psi when upto temp
    Body by Holden, Soul by Brock
    the Legend will live forever
    Nov 2008
    rotorua, NZ
    in the last 2 days ive noticed that mine gets up to and stays arround 100c (goes over but not under) i have noticed that the gauge is a lil dicky tho and under heavy breaking the temp rockets up, the needle bounces when the indicator is on and when the sterio is up loud or under a heavy bass load it bounces arround lots, but the normal temp is between 100-120c, again im prety heavy footed, actualy i think my foot is made of lead but most of the time its between 100 and 120, ive noticed the same with the water temp, has little or no effect on oil temp and my oil pressure is arround 4bar under normal conditions, but when the oil is hotter (around 100c+) it sits around 3 (some times 2) bar, when im off the throttle
    sounds prety similar to yours!
    you power it down!
  1. My HP Readings :(
    By VPCalais38 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2008, 08:10 AM
  2. sv6 dyno readings
    By naf33n in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-01-2007, 05:25 PM
  3. odo readings
    By vt_lover in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2006, 02:42 PM
  4. help on diagnostic readings(ECM)
    By dougie tas in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2005, 06:00 PM
  5. help on diagnostic readings
    Last Post: 05-03-2005, 07:34 AM
