Results 1 to 12 of 12
Thread: $960 later the VS still breaksdown, whats left?
    VS3 Commodore Ute
    Dec 2008
    Default $960 later the VS still breaksdown, whats left?
    G'day
    I'm chasing a random problem where the engine will die, you could be driving or idling at the lights and the problem will happen. The problem doesn't happen all the time, the car can drive good from Brisbane to Gold Coast, but then constantly breakdown when driving down to the post office. Then if you do the same thing the next day it might do the exact opposite! When the problem occurs I will lose power steering and (power) brakes (ie they become "hard"). Also you won't always be able to instantly start up the engine, sometimes I have to wait awhile and then try again.
    So far I've replaced the following and the problem persists:
    Ignition Module
    All coils
    Spark Plugs
    Fuel filter
    Air filter
    Oil filter
    Fuel pump
    What is there left to replace that could be the cause of this problem?
    Should I replace the Crank Angle Sensor next? Would an ECU cause this problem?
    Whenever I take it back to the mechanic he checks the computer as faults are being logged but he never says anything to me when I pick up the car. So i'm guessing by the time I give him the car the faults clear?
    Looking at other threads it looks like the crank angle sensor would be the next thing to replace.
    Cheers for any advice given.
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by pengoau View Post
    Should I replace the Cam Angle Sensor next?
    Crank Angle Sensor. Sounds like classic symptoms of the CAS.
    You can also check error codes yourself using this page:
    Checking error codes VR/VS (Revised)
    COMMY VP 666's Avatar
    COMMY VP 666 is offline COMMY VP V6
    COMMODORE VP
    Dec 2008
    first sounded to me like ecu, and cas
    try a different ecu. not sure about your mechanic, come dont have the scan tool but
    id say try and get your hands on another ecu, and see how it goes, or if a error code comes up get someone who has the tool to get the code
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by _R_J_K_ View Post
    agreed!
    how many kms on the clock?
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    VS exec
    Jun 2009
    bong from the gong
    The brakes becoming hard sounds like a classic sign of a vacuum leak, but might just be a affect of the car not providing vacuum due to the problem causing it to break down.
    I suggest checking the codes and writing them down, check the how to section for the info on how to and what they are, then clear them the info should be in the same thread. This will give us error codes that might still be in the history, pot them here.
    and get rid of them. then after the problem happens again check the error codes write them down once again post them here.
    then we can try and trouble shoot from the error codes
    VS3 Commodore Ute
    Dec 2008
    VS
    Oct 2008
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    hi, it was the CAS. thanks.
    cheers for updating us on the fix, hopefully this will help others too
    1998 vs s3 ute
    Jul 2009
    near blacktown
    hope it helps me im going 2 buy 12 2 day car got the same problem
    ill let yas no how it goes
    shiftySLE's Avatar
    shiftySLE is offline The Lion will never Die!
    VH SLE, VZ Acclaim
    Jun 2009
    change the crank angle sensor, cam angle sensors are a different problem all together
    Croydon is offline Croydon
    VR Exec 3.8 auto wagon, bench seat
    Jun 2009
    NZ
    Hi folks. I have had this problem recurring on and off for quite a few years with my 95 VR wagon. Changing the CAS by the agents lasted for less than 50km before it stopped dead again. On my one, the problem is dodgy electrical connections in the loom (verdigris, etc) and poor earthing on the DFI module that the coils sit on. You can actually see the film of corrosion on the bottom of the modue. It is not envirmnomental, as the car lives well inland, and is garaged. Only abt 3,000 km / yr, though. Latest try fix is a marine electrical sealant (lanolin based). Fingers crossed.
    I would recommend anyone with this problem to go through connections (particularly the loom joints behind the battery) and clean off the bottom of the DFI and the plate it mounts on.
  1. Front left quarter panel - whats it worth?
    By reformed99 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2008, 03:16 PM
  2. Whats left in a service ?
    By Ron41 in forum General
    Last Post: 30-04-2007, 10:51 PM
  3. Swapping left to right????
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-12-2006, 08:37 PM
  4. left or right?
    By Troy711 in forum The Pub
    Last Post: 28-02-2006, 01:28 PM
  5. How to take out vr left headlight
    By gmhvr-6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2006, 09:34 PM
