hey all
im finding with my 5 speed when i change gears it feels like the gears are like nicking each other when i change from say first to second but often second to third. i had the fluid changed recently and looked ok. just wondering can u do anythin bout it. doesnt feel right
VS SS - Street/Show Project [BEEFY]
http://forums.justcommodores.com.au/...-beefy-v2.htmlHID Kits from $100 - Installation available PM FOR DETAILS
i think i know what you mean. you push it into third and it sounds like a something hits something spinning? ive read thats the main cause of wear in these boxes
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
you use the correct grade of oil sounds like a syncro issue might be too think of a grade of oil
yea it happens often with mine.. doesnt feel right
i didnt do that service myself i had a gearbox joint just check it because my thrust bearing is noisy as hell
what would cause it 2 do this so much
wrongly adjusted clutch cable if you have cable not hydraulic or the syncro for 3rd getting worn or too thick/thin oil.
Hey chris, could be incorrect pivot ball height. i had this problem when i changed my clutch. sus that out
Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
