Results 1 to 8 of 8
Thread: cruise control-blinkers???
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Default cruise control-blinkers???
    Can someone maybe point me in the right direction?
    Anyone who knows me knows I am hopless with anything mechanical, This time however I am clueless?
    For some reason my cruise control is not working. I checked the fuse but it's fine but I have noticed that at the same time I lost my cruise control my blinkers stopped turning themselves off after rounding a corner. They sometime turn off and you can hear the clicking and I wanted to know if this might be the cause of the cruise not working?, and if not, what else should I look at?, I'm driving a 99 S ute. Thanks...
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I suspect the indicator stalk may be the problem.
    MY RIDE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As above - maybe the indicator stalk has been dislodged from it's mount - you can drop the panel under the steering wheel to access the switch mount. Disconnect your battery first!.
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Question
    Is there anything else I should be looking towards in relation to the cruise control?, I did as you said but couldn't see anything that really seemed out of place?
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by ianf View Post
    Are the cruise control controls on the indicator stalk? I can't remember.
    MY RIDE
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The cruise won't work if a stoplight bulb is blown, or one of the two brake switches are out of adjustment or relay is not working. Does the cruise light come on?
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    If your high beam flickers when you flick the stalk to indicate then theres the problem.
    Anywho... Change the stalk and go from there.
    99 VS 'S' Utility
    Dec 2006
    Lansvale NSW
    Cheer's, you were spot on!, it turns out it was a stop light that had blown and as soon as I replaced it the cruise was fine, thanks again...
  1. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  2. Cruise Control
    By Summer-Sickness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2007, 08:01 PM
  3. Cruise Control Into VN SII
    By slimman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-10-2006, 03:40 PM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. cruise control no control
    By foxinjox in forum Electrical Wiring / Questions
    Last Post: 16-11-2005, 01:32 PM
