Results 1 to 23 of 23
Thread: VS Tips and Tricks - You May Not Know About
    96 VS Executive S II
    Feb 2006
    Perth,WA
    Default VS Tips and Tricks - You May Not Know About
    Hey all, sorry if this has been covered before, i did search and couldnt find anything - after floating around on the forum, I've found a couple of tips i have found that are awesome. the only ones i know about are:
    Deadlocking - Locking the car with the key after you have locked with the remote(please correct me if i am wrong)
    VS Speedo Alert - Turning it into a Digital Speedo - turn car onto ACC and hold down all three speed alert buttons until 100 flashes then press SET.
    If anyone has anymore please add, I think Commodore owners would love to know this stuff(If they don't already)
    <insert something funny here>
    VQ Caprice II
    Aug 2006
    Deadlocking was on most of the V' series models.
    Turning the Key to the horizontal positon achieves this.
    But it only worked if there was a trigger switch behind the handle that locked all the central locking modules down.
    Another feature was pressing the two buttons together when turning on the car, it then gave you (if you had level 3, cluster) fuel pump pressures, alternator voltage, and other cool stuff. Great for fault finding fuel-air locks.
    Digital speedo was around from VN Calais.
    Yes alot of people know but some facts get forgotten...
    Feb 2006
    Perth,WA
    damn, wish i had a level 3 dash now, thats awesome...anyone got anymore??????
    VS_Pete_1's Avatar
    VS_Pete_1 is offline Donating Member
    VE II SV6 MY12 Sportwagon
    Dec 2007
    Quote Originally Posted by spirto View Post
    Hi mate where do I find out all the features of a level3 cluster???
    "Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
    My VS II Berlina Wagon
    MY12 II SV6 Sportwagon
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    See:
    Unofficial Holden Commodore Archive - Technical Tips
    To paraphrase:
    Start the special functions: press MODE and RESET while turning the ignition on (The computer will do a self diagnostic check and display the word 'FAIL' if it finds an internal fault). Press mode to swap between the different displays.
    Display 1: Speed in km/h, fuel in L/h, Button Test.
    Display 2: Battery Voltage, Fuel tank sender Volts (full ~4.4V, half ~6.6V, empty ~8.5V), Button Test.
    Display 3: Energise all segments of the display.
    The button test shows a '0' each time a button is pressed. Each different button will illuminate a different spot.
    Anyway it seems to be the same for my VS - not sure about the fuel pressure mentioned in a previous post though?
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    THANKS FOR THE SPEEDO TIP~!!!
    it works on my VR Series II. Hold down both arrow keys while turning key over
    thanks again!
    The_Lexman is offline Man with Lexcen
    '95 VS Lexcen CSi
    May 2009
    That speedo tip is pretty cool, only thing is that it doesn't match up with needle on my normal speedo, the digital speedo is about 5 k's to slow. Oh and theres a bright orange flashing light that bugs the hell out of me, any idea how to turn it off?
    Stressball's Avatar
    Stressball is offline Rolling on 4 again :D
    Mitsubishi Triton
    Oct 2005
    SE QLD
    Quote Originally Posted by The_Lexman View Post
    Analog speedos generally do over-read, better to over-read than under-read. Your digital is likely a little more accurate, not spot-on though.
    VB SL/E
    Dec 2008
    On my VR if I hold the set button down in normal operation (not the test mode) then in each different mode I get three extra functions pop up, one gives me tank litres and a calc in the second and third window, the second set gives me distance calc in the second window and the third gives me a fuel calc in the second window.
    The second and third calcs mentioned are variable via the up and down buttons.
    Can anyone tell me what they do?
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    i think thats to calculate the fuel in ur tank, u can set it up exac, so uno exac whats in ur tank.
    Ujst have to fill ur car to full a couple times n set it to that full amount then check on the nxt fill to see how close u are
    its a bit fiddly to get exac, takes a few tanks to get it right, jst have to check the amount what was in the tank b4 filling, then check to see if it adds up to the right amount once u added x amount of fuel.
    So say u have full tank 63l, then when its half u fill it to the top again, added 33L, u total b4 filling should have read 30L, then when full reads 63L, takes a few full tanks too get it right
    ________________________________________
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    Yeah, they are just for calibrating the trip computer. You can do a search and it will tell you exactly how to do it.
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    Theres no way to turn off the led flashing led while in digital speedo really. I changed my led to blue which looks much better in daylight, but at night its super bright so i put some black tape over it.
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by aceventura View Post
    See:
    To paraphrase:
    Ive done the digital speedo trick in my VS now can i do them same things to my lil digtial speed alert thing?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
    No, sorry - I wansn't all that clear in the previous post. The extra functions are for L3 instrument clusters only (i.e. with trip computer).
    The speed alert trick only gives a digital speedo.
  15. #15
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Ohh ok dang
    Its all good mate
  16. #16
    VY Berlina
    Mar 2009
    Sydney, Australia
    Hey guys, thanks for the tip.
    I've done the digital speed showing on my speed alert and it works perfectly fine. The orange LED is a bit annoying but I haven't driven with it on at night, I'll see how I go. Maybe colouring in the LED with black permanent marker will avoid it blinking too brightly?
    PorkoWogVisit MeContact
    Looking for or in need of free or paid hosting?
    Please contact me now for more information.
  17. #17
    HSV VT GTS
    Dec 2008
    Quote Originally Posted by almost_skater View Post
    yes there is, hold all 3 buttons down when turning the car over until the engine light flashes, then i think press 'SET'.
    this also makes the digital speedo permanent until you do the reverse.
    permanent speedo and no flashing orange light
    Bite off more than you can chew, then chew like hell - Peter Brock
  18. #18
    Verynice's Avatar
    VS Caprice 5L
    Aug 2008
    oh ok ill try it out, as i said, i changed my led to blue and its quite nice to drive with
  19. #19
    VQ Caprice II
    Aug 2006
    looks like the questions asked to me, have been anwered..
    cooool coool lol
  20. #20
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    My speed alert doesnt blink when driving. Did you press set after activating the digital speedo? Maybe you need to set the speedo alert function to a higher speed.
  21. #21
    seraphic06's Avatar
    seraphic06 is offline Woodgrain Nut
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Can someone post a link to this? I am buggered if I can find it.
  22. #22
    aceventura's Avatar
    Mazda 6
    Oct 2008
    SEQ
  23. #23
    seraphic06's Avatar
    VS Esteem SII Wagon
    Sep 2008
    Adelaide, SA
    Thanking you. I am now wondering why my owner's handbook does not have this information?
  1. Detailing Tips & Tricks....
    By Lish in forum General
    Last Post: 08-04-2012, 11:31 AM
  2. VR V6 Engine swap tips/tricks?
    By XeKToReX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2008, 05:40 PM
  3. Remove Factory Stereo Tips/Tricks
    By ozzie_online88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-06-2008, 06:25 PM
  4. Dealer Tips & Tricks
    By Twenty2 in forum General
    Last Post: 11-11-2007, 05:34 PM
  5. Painting engine covers - tips/tricks?
    By familyguy in forum General
    Last Post: 09-01-2006, 05:39 PM
