Results 1 to 13 of 13
Thread: Need help asap!!car wont start!
    vr statesman 5.0
    Jan 2009
    Default Need help asap!!car wont start!
    bloody car wont start and i dont know y.ive tried everything.when i turn the key it makes a ticking sound and thats it,just 1 tick.the starter motor is brand new only 3 months old if that,the sparkplugs are brand new and same with the battery.ive even tried hitting the starter motor while trying to start it as well as jump starting it but they do nothing!anyone have any ideas?it did the same thing last week then when it got off the tow truck at the mechanics it started 1st go! now its ****ed again and its ****ting me. PLEASE HELP!!
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    probably a loose connection on one of the battery terminals or at the starter could be the fat wire or the little trigger wire at the starter give the little one a wiggle and try it .try to crank it a few times then feel the battery terminals and the connection at the starter for heat if its hot anywhare its not making good contact
    vr statesman 5.0
    Jan 2009
    just took the battery terminals off cleaned em and put em on tight and that didnt work.i will try that to the starter motor in the morning.thanx for that mate
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Could be your fuel pump. Can you hear the fuel pump prime when you turn your car to On (So that would be the turn before kicking it over).
    vr statesman 5.0
    Jan 2009
    just checked that and no cant hear anything.i just got an external fuel pump put on and the internal pump is like 3 months old.
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Did you get a new solenoid when you got the starter motor? It could be the solenoid that is attached to it that needs cleaning/replacing. Give that a check tomorrow.
    vr statesman 5.0
    Jan 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check the "start relay" - that's the one that powers the starter solenoid. The relay is located in the engine bay next to the battery - check by swapping with another from the relay panel.
    Re the starter motor - was it "brand new" or second hand?...if the latter then I'd suspect that.
    vr statesman 5.0
    Jan 2009
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Sounds like the cable between your battery and starter motor is not connecting properly. Put the front of your car on stands and measure the voltage to the starter motor when (somebody else) turns the ignition key to start. If you're not getting 12 volts then you either have a bad connection at the starter motor or the cable is corroded somewhere.
    VS Statesman SIII 5.0 V8
    Apr 2009
    I had a similar problem with my V8 Statesman... ended up being the fuel pump fuse (duh!)
    Also doesn't start sometimes due to a dicky gear selector solenoid.. doesn't think it's in gear I guess.. a few quick changes on the gear selector and it fires up.
    VS CAPRICE
    Dec 2008
    Sunshine
    Check that the cables from the battery to the started are tight not loose. Look for the simple probs first....
    vr statesman 5.0
    Jan 2009
    thanx for the help guys its at the mechanics now
  1. statesman 5l wont start!! ecu maybe a problem??? need help asap!!!
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2010, 07:20 PM
  2. vk wont start
    By SKITZ6 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-05-2008, 09:17 PM
  3. Front door wont unlock please help asap
    By stumps5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2008, 09:35 PM
  4. VN wont start
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 11:59 AM
  5. Key wont turn and acts as if steering whel is locked need help asap
    By gemini in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2006, 11:03 PM
