Results 1 to 7 of 7
Thread: Electrical bug
    1995 VS Sedan
    Apr 2009
    Default Electrical bug
    Hi everyone
    I have a bit of an electrical problem on my VS. I got the engine changed over and noticed when I picked up the car (I was a few hundred kms from the mechanic already) that the rear lights and the lights from the dash were not operational anymore. The stop lights works fine though. I noticed as well that the speed alert display is still backlighted but its not operational as well..
    Another problem, maybe related to the first one: I noticed that when I sometimes leave the car parked, the back lights stays on (but dim) even if I took the key out.. So I have to unplug the battery when this occur to avoid loosing the charge over night.
    So I'm thinking, there must be a cable or a fuse somewhere that might be buggy or kinked or maybe a harness but I don't have the electrical diagram in mind so if anyone knows well how the electrical network is operating on the VS and knows if there is something that may cause the dash and the rear lights to both go nonfunctional, drop me a line.
    Thanks.
    1995 VS Sedan
    Apr 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Only things I can suggest is to have a look around where the battery is located and make sure all cables have been re-connected after the engine change-over as it sounds like you have a bad earth somewhere. Next when you notice the backlights on, remove one fuse at a time (and replace) then the next one till the backlight goes out - this will isolate the circuit that's causing the trouble. Also try removing relays one at a time both under the steering wheel and the ones in the engine compartment. Hope that is of some help. Good Luck.
    1995 VS Sedan
    Apr 2009
    Thanks I'll try that.. Apparently, there is a bad contact under the steering wheel, that may cause the lights to stay on. Now for the backlights + dash not working, I'll have a look closer around the battery.
    Do you know where I could get the full electrical diagram of the vs?
    1995 VS Sedan
    Apr 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Gregorys has 13 pages of diagrams which is a bit much to Email. Public libraries hold manuals which you can borrow. However PM me your email address and I can send what I think are the most relevant pages.....probably engine, interior and exterior illumination.
    VS Clubsport
    Nov 2008
    Auckland
    From memory the dash lights and tail lights (excluding brake lights) are on the circuit so you may have a blown fuse for that particular problem.
  1. Electrical Pre-voc
    By greenvs in forum The Pub
    Last Post: 03-01-2009, 05:27 PM
  2. electrical problem...
    By lilkel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2007, 05:10 PM
  3. vk what the (electrical)
    By old55 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-03-2006, 10:12 AM
  4. vl electrical
    By basterdvl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-11-2005, 11:51 PM
  5. electrical
    By Mark in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2004, 07:26 PM
