Results 1 to 7 of 7
Thread: Are VS axles longer than VN?
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    Default Are VS axles longer than VN?
    Or is it just the diff housing?
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    I thought the housing and the axles were the same length.
    Yours Kindly,
    Jim
    Jun 2006
    Western Aus.
    Wagons/Utes everything was the same length. (have been through a few diffs from utes and wagons and measured them)
    In sedans, apparently there was a change from VP to VR... Hopefully someone has the correct information on this.
    Hot Lap Motorsport
    VP Executive R-spec
    Jan 2005
    The Rear track is different between the VP/Q IRS cars and VR/S but it's the hubs that are wider. Live axel cars are all the same
    Dec 2008
    Hmm, doesn't explain why my "vn" diff is shorter overall than my vs diff. The housing is about 5cm shorter, but im just wondering if the axles are also shorter.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by maldotcom2 View Post
    If the diff housing on the diff currently in your vn is shorter than the vs diff housing you're comparing it too than the axles will be a different length and wont be interchangable. It sounds like its not actually a standard vn diff and is likely a vl diff (which is the same as the vn group A diff). Some people fit these to late model commodores because with the narrower diff it allows you to fit wheels with a really deep dish/big offset. Standard sedan live axle diffs are the same from vn-vs.
    Dec 2008
    Ah i see. So either way i can't use my VS axles to bring the wheels out further. I hope it's a vlt diff, if it's 25 spline im going to be very pissed off.
    Thanks.
  1. VS axles into VN Housing LSD centre ?
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2008, 07:13 AM
  2. VP IRS Axles
    By Reaper in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-12-2007, 09:37 PM
  3. VN Diff Axles?
    By cohn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2007, 01:56 PM
  4. VQ and VS irs axles same?
    By stumps5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2006, 11:59 AM
  5. removing vl axles
    By schoey in forum VL Holden Commodore (1986 - 1988)
    Last Post: 16-05-2006, 04:20 AM
