Results 1 to 6 of 6
Thread: Broken Bolt
    VS Calais S1
    Jul 2006
    Kadina, SA
    Default Broken Bolt
    Ok guys so i feel like a pretty big idiot for doing this, but recently i replaced the rocker cover gaskets due to an oil leak. Checked today and one of the rocker covers was covered in oil still, so i figured maybe the bolts were a little loose. Went through and checked em all, went to tighten one and snapped it off Anyway anyone got some advice on removing the snapped bolt?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it's not snapped off below the head level you could remove the rocker cover and grip whats left of the bolt with pliers or vycegrips...if it's snapped off below the head deck level and you cannot grip it you can buy left hand threaded drills which drill into the broken bolt and unscrew it whilst drilling or use an "easy-out" but if they snap you have a bigger problem. You may also be able to use a centre punch to slowly and gently tap the bolt anti-clockwise.
    Others on the forum will have other methods.
    Good Luck.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    I did a similar thing on my plenum chamber bolts. Torque wrench didn't click. That's an issue for next time i want to remove it.
    VS Calais S1
    Jul 2006
    Kadina, SA
    Just took off the rocker cover and took a closer look, the bolt is to far in to get a hold of it and twist it out. Had a chat to a mate and he had a set of "easy-outs" that i could use but dont really feel confident enough to do it incase i screw things up even more, looks like i am going to have to leave it to the pros, am i going to be alright to drive it like it is only bout 5 - 8 kms to get it into town?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    easy-outs are simply that, easy! use them and it'll only take 5mins tops!! you wont screw it up, it just kinda drills/taps into the head bolt then you can remove it by undoing it. really really simple and it'll cost you nothing!
    if you really need to, yea it'll be fine if you end up taking it to a pro 5-8kms down the road, worst thing thats gonna happen is throw some oil out that section. wont be much thou.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    weld a nut onto it and then use a rachet easy as using easy outs
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
  1. How do get bolt out?
    By blinky phil in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-05-2009, 09:34 AM
  2. 304 bolt ons
    By apoc585 in forum V8 Development and Modification
    Last Post: 09-11-2008, 03:55 PM
  3. 8 bolt Flywheel
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-05-2006, 08:37 AM
  4. bolt for t5
    By VN-88 in forum The Pub
    Last Post: 27-04-2006, 10:10 PM
  5. broken bolt HELP
    By AnthsVSLexcen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-12-2004, 01:40 PM
