Results 1 to 4 of 4
Thread: holden calais V6 Inlet Or Head Help ?
    Vr S2 Calais
    Jan 2009
    Default holden calais V6 Inlet Or Head Help ?
    Hi all how can i tell if my Inlet manifold gaskets are worn or leaking because i have oil in my coolant but not water in my oil what would this be my gaskets or head is stuffed. but i have a slugish ice coffee look on my oil cap the size of a 5 cent coin would that mean my head is stuffed or is it because i havnt used it in a long time
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Hopefully it's because you haven't used the car for some time and/or its been used for short runs which doesn't allow condensation etc trapped in the oil to escape - in bad cases you will get a milky deposit under the oil filler cap and this problem is worse in cold weather. If you are really worried about it just remove all your sparkplugs and check them for 'strange' deposits.
    Vr S2 Calais
    Jan 2009
    cheers hako you calmed me down as i havnt used the car in about 5 weeks but turn it on for 5mins every 2 days
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You're probably better off not turning it on for 5 minutes every 2 days as that will just make the problem worse - it needs to be run till it reaches operating temperature or not at all. Also if worried about the battery when car is left for some time just disconnect....it will still be charged in 5 weeks time and no harm will come to an engine that hasn't run for 5 weeks. Good Luck.
LinkBacks (?)
  1. Performance Inlet Manifolds - HOLDEN V8 304
    By RVN 355 in forum V8 Development and Modification
    Last Post: 28-08-2011, 12:31 PM
  2. Holden VY Head Unit
    By Alec7565 in forum Car Audio
    Last Post: 10-10-2008, 07:28 PM
  3. SA: VL Head, inlet manifold, water and oil pump gaskets, valve seats
    By VL Berlina 5speed in forum Parts And Other Items For Sale
    Last Post: 13-06-2008, 03:11 PM
  4. Holden V8 Twin Throttle Inlet
    By Daza in forum Parts And Other Items For Sale
    Last Post: 28-12-2007, 08:08 PM
  5. 5L head, cam and inlet mods
    By vtss5spd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2006, 07:14 PM
