Righto,
At this stage Im pricing up my next project.. plans would be ecotec (series 3)& Convert to manual..
I know a few of you have done a this conversion, so whats the guts?
So Im looking at buying a VS with the series 3 motor, or buy as a complete motor with ancillaries (loom, coil packs, ecu etc etc)
Would then have to source a (T5 or Getrag?) gearbox from a VN-VP (most common that I can find readily available).. I've heard some motors are 6 bolt & others 8 bolt ?? what identifies either type? And what problems will I encounter/have to fix..
Have no problems fitting up g/box's etc so thats no worry..
Apart from the box & tailshaft itself, what else do I need to make it run?(note this wont be going into a commodore)
Any advice/information appreciate thanks..
i am currently undertaking a manual conversion
and you will need the getrag 5 speed for the series2 upwards other wise the boarg warner i think... may be wrong tho
-pedal box
-clutch
-clutch cable
-manual flywheel
-manual computer
-wiring loom (manual)
-starter motor (manual)
hope this helps out some how ..
also im interested what this set up will be goin into .... gemini maybe ??
T5 gearboxes were from the earlier models up until late VS or maybe VT, they have a cable clutch. Getrag boxes are apparently stronger and use a hydraulic clutch, but clutch replacements are more expensive. Pretty sure you could use either one, someone will chime in with more info on this, i'm looking at a T5 for my VS.
