Results 1 to 8 of 8
Thread: Can You Resolve My Problem? -- Cooling System On VR
    social's Avatar
    social is offline Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    Default Can You Resolve My Problem? -- Cooling System On VR
    Hey guys,
    Il get straight to it. Work as a apprentice Mechanic at MTA and had the car on the hoise to examine, turns out had a leaking water pump, seal obviously went in it. After driving around for a few days, i came across a smell, closest i can explain to is of hot wax, and it was coming through the vents when i went stationary when driving the car (eg. stopped at lights). Now to fix it up, i went out and bought a brand new water pump, thermostat and also a radiator cap just incase and installed them properly, removed the radiator and thoroughly flushed it with a hose, then filled up the system with brand new coolant, bled it and it all worked prefectly. Now although my temperature reads 1/3 Hot after a decent drive, which is fine, i open up the bonnet after a bit of a long drive and get that same waxey smell and feel that the radiator cap isnt hot at all, not even midly warm at times. I think i narrowed the smell down to the radiator side itself where the cap goes. What could cause this? Can i fix it? And should i be worried?
    Thanks in advance,
    Social.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Is the upper radiator hose hot? How long is "long", we are into winter. Does your heater work well? Is the bottom radiator hose hot?
    Sounds like the there could be a blockage in your water galleries - clearly there isn't one in the radiator if you were able to flush it.
    Stupid question, but did the thermostat go in the right way?
    The 1972 HQ Kingswood
    social's Avatar
    Nov 2008
    South Aus
    Quote Originally Posted by Morton View Post
    Hey morton cheers for the reply, yes the upper radiator hose is hot, long as in.. like 45mins+ of driving. Yes the heater works fine, and as for the bottom radiator hose i didnt check that so will do next drive
    What can get rid of a blockage in the gallaries?
    As for the thermostat it was a very nice snug fit, like, have to just apply a bit of prssure to it and it kinda clicked in, and was put in the correct way also.
    social's Avatar
    Nov 2008
    South Aus
    bi of an update, the smell is still lurking around although the radiator cap get hot now, so.. yea still unsure whats causing it.
    vnss
    Jan 2007
    wyndhamvale vic
    mate have quick check of your heater tap in the engine bay. they are the worst design and are prone to rusting a hole in em and leaking coolant very discretely. this hole can also let air in the system and yeah, hot spots form. good luck
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    The waxy smell is possibly hot coolant evaporating - does the car lose coolant?
    social's Avatar
    Nov 2008
    South Aus
    just an update guys, ive found a tiny little leak from where the bottom radiator hose meets the block, going to replace it tommorrow and hopefully thats it
    CALAIS 6's Avatar
    CALAIS 6 is offline snowballing
    98 Triton mini truck
    Aug 2005
    Adelaide,Tea Tree Gully
    was going too sugest the bypass hose from water pump too block but sounds like u found ur prob????
    [SIGPIC][/SIGPIC]
  1. My Cooling System... Help
    By Explosions Hurt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2008, 09:03 PM
  2. Problem Flushing the Cooling System
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2007, 01:38 PM
  3. V6 Cooling System
    By tja_bot in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 11-03-2007, 01:27 PM
  4. Oil in the cooling system?
    By portercg in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-12-2004, 11:43 PM
