Results 1 to 4 of 4
Thread: Which auto transmissions will fit the VS?
    VS Executive
    Aug 2008
    Default Which auto transmissions will fit the VS?
    Gentlemen,
    The auto in my 8/96 VS Series 2 has given up and I need to source another one from a wrecker. I'm aware that the VR auto will not suit. Will the VT transmission fit, or do I need to chase up a VS unit specifically?
    If we have any transmission specialists on the board I'd really appreciate any assistance. I've had a search of past threads however I can't seem to find a definitive answer.
    Many thanks,
    Russ
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    There was a similar thread on here recently. From memory the answer was that you are best to stick with a VS box. The VT box has a different plug i think !?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    VT has a separate bellhousing and needs the exhaust modified to fit. Easiest to source a VS box as greenacc says - either 5HDD, 6HDD or 7HDD. VR has the different plug. 80% sure that's correct!
    VS Executive
    Aug 2008
    Thanks guys.
  1. Transmissions
    By acarmody in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2008, 05:20 PM
  2. transmissions
    By VR 3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 11:00 AM
  3. Transmissions
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2005, 04:48 PM
  4. Transmissions
    By VPower in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 04:57 PM
