Results 1 to 5 of 5
Thread: Where the hell is the Crank Angle Sensor?
    VS3 Commodore Ute
    Dec 2008
    Default Where the hell is the Crank Angle Sensor?
    G'day
    Going to get my CAS replaced, just wondering if its a part that even an idiot could replace? If so I could fix my problem quicker than having to wait to drop off the car to the mechanic and get him to do it. Which due to work, I can only do on a Saturday.
    Also problem I think happens coz the CAS is overheating as the problem occurs after driving the car for more than say 30mins. So I've read here pouring water over should cool it down and get the car running again.
    I've done a google search and got a rough idea of what the part looks like but not where it would be located in my VS3 UTE.
    Can anyone give us some advice? Looking down at the engine whereabouts is it? Anywhere near the ignition module?
    Would a Gregory's manual give me diagrams and a good guide on how to replace it myself? What sort of tools do I need? I only got a adjustable wrench, some screwdrivers and a hammer ;P
    Cheers.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    its behind the harmonic ballancer
    you need a puller to get the ballancer off other than that its a relitively easy job
    VS3 Commodore Ute
    Dec 2008
    Where is the Harmonic Ballancer?
    Can you give us directions from looking down at the engine bay? I'm mainly asking so I know where to tip some water when it plays up, so I can get going (as a temp workaround till it gets replaced). Thanks
    VP Executive R-spec
    Jan 2005
    It's the round thing that's bolted to the front of the crankshaft (and the belts are attached to)
    Steve Ashton's Avatar
    Steve Ashton is offline Proud Commodore Owner
    vr series2 executive wagon
    Mar 2009
    Brisbane Australia
    It's not too hard a job , but a novice should watch someone else do it for the first time. Or follow the good book closely. You could end up damaging something including your radiator, good luck.
  1. Crank Angle Sensor
    By RockyC in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2011, 09:02 PM
  2. Crank angle sensor?
    By sportyclansman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2008, 01:10 AM
  3. crank angle sensor help
    By BOXMONKEY in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-03-2007, 01:04 PM
  4. crank angle sensor
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2006, 05:35 PM
  5. Crank Angle Sensor. WHY??
    By Chuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2004, 08:02 PM
