Results 1 to 8 of 8
Thread: The Sort of BT1 VR V6
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Default The Sort of BT1 VR V6
    Thought it would be about time I chuck some pictures of the ride. No interior shots because it's factory and every one knows what they look like.
    Super_Low 91's Avatar
    Super_Low 91 is offline ┌∩┐(◕_◕)┌∩┐
    Nimbus 2000
    Sep 2008
    Hogwarts
    This car is definitely a work in progress. Its changed so much from when you first picked it up,,
    Signature Goes Here
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Put this up late at night and didn't even bother to do a write up. My bad folks. Well here's the spec sheet on the "semi BT1" and a bit of a story of how we came to be together.
    Managed to find this car at the wreckers for $500. Had to have a cheap run about as Dum*p*ster had enough of me borrowing his ride haha. Didn't realise at the time as the glove box was locked shut but it had the original logbook in it which stated the original owner was the Commissioner of Police how ever the build plate doesn't state BT1. Also didn't realise at the time because it was an ex cop car had the LSD which was a nice bonus the vinyl carpet however wasn't. Took her home gave her a clean and found all it needed for a roadworthy was a degrease and engine mount then it was out terrorising the neighbourhoods in my town.
    Model: 1994 Holden Commodore VR Executive
    Rims: Genuine 15 X 7 Interceptors with Genuine centre caps
    Current Engine Modifications:
    70MM Mace Throttle Body
    Depending on my mood I either run a pipe off the TB into a pod filter (omg hot air) or the standard air box and pipe with homemade CAI and K&N panel filter
    Pacemaker Extractors
    Ballistic Racing 100cpi high flow cat
    Cat back system with Redback muffler
    Mace mail order tune
    Future Engine Modifications:
    3.9 diff gears
    High ratio rockers or a cam
    Current Body Modifications:
    Fully debaged as well as door strips taken off (Planning on getting new Holden or HSV badges as am sick of the holes)
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    Couple of pictures.
    Got bored and decided to run a black bonnet for a while. Surprisingly cop's liked it.
    Pretty much bog standard there. Only had a cat back exhaust from memory.
    Nimbus 2000
    Sep 2008
    Hogwarts
    nice black bonnet,, looked good when it was on the 18's with it,, should so do it again lol
    Signature Goes Here
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    93' Pov-Pac
    Jul 2010
    Sounds alright. Did the high flow cat change the note much?
    And how's the vr go with the 70mm TB?
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    The high flow cat surprisingly did change the note a bit not to mention the throttle response. With that and the 70mm the VR is very responsive.
  1. What sort of Amp?
    By SUSS8 in forum Car Audio
    Last Post: 20-02-2010, 10:35 PM
  2. what sort to buy???
    By Nackerz in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-02-2010, 07:54 PM
  3. what sort of cam vn ss
    By 94calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2008, 05:57 PM
  4. What Sort of Dog is this?
    By Jesterarts in forum The Pub
    Last Post: 15-06-2008, 02:07 PM
  5. what sort of value?
    By sircruisealotVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 02:08 PM
