Nah mate it had a 2.5 catback on it before all the work. When the engine got rebuilt it needed extractors. The exhaust shop happened to be right next door so he knew what my car was getting done to it, so we decided to use the cat back and chuck another cat on because of the extractors are designed for a twin cat setup. I wasnt too sure about the pipe sizes but it runs great and sounds sweet too. All the work was done at the same time as the auto shop, engine shop and exhaust shop where within 20m of each other.
Adzzaman Now Available In Surround Sound
You dont need to do much to a VR/S to get them looking nice...
nice 1 !!!
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
cheers boys![]()
Had a run on the dyno today as you can see. Still a few more things to sort out but its slowly getting there. Im pretty happy with how its all going.
Well on the way to a certain charity crusie I managed to loose 3rd and 4th gear. No drive what so ever. Had to drive from sutton forrest back to canberra in 2nd at about 80k's the whole way, good way to check out the sceneryGonna try get it into the shop next week sometime to hopefully sort out the problem.
does a v8 throttle body just bolt up or do you have to get an adaptor plate made up? ooo ur running same spring set up as me...nice looking car =D
