Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 101
Like Tree3Likes
Thread: VS II 185I Senator
  1. #76
    VS Senator
    Oct 2009
    Ok so i pulled the diff out and i have striped about 3/4 of the teeth of my crown wheel. Other than that the inside looks good so it should only need to be cleaned out and my new gears put in. More bad news tho as i found my cradle has started to crack above the diff housing so i need to get that repaired befor i can put the diff back in.
  2. #77
    VS Senator
    Oct 2009
    This afternoon had a mate come round and welded up the cradle so one job down. The diff goes in tomorrow to get the new gears in and to make sure there are no nasties in the lsd itself.
  3. #78
    VS Senator
    Oct 2009
    So the diff is back in. Got the lsd reshimed and its all good. And then the centre bearing went in the tailshaft. Got that fixed today so now its all sorted.
  4. #79
    VS Senator
    Oct 2009
    Ok so t wasnt the centre bearing that was broken it was actually the yoke and uni joint. But its all good now.car drives heaps better. The 3.9s make a nice change to taking off.
  5. #80
    STL17's Avatar
    STL17 is offline Whipit
    VS STATO , VP EX COP
    Aug 2009
    townsville
    no1 likes your thread ay
    tuning done by THE1 A+++++ tuner
    And powering it by MACE
    Build it to handle the MANG
  6. #81
    VS Senator
    Oct 2009
    Quote Originally Posted by STL17 View Post
    dont be jealous of the v8 brad. Lol
  7. #82
    VS 5 Litre BT1
    Jul 2006
    I do...particularly the pics after the detail.
  8. #83
    VS Senator
    Oct 2009
    Cheers mate. I willl have to put up pics of the diff gears to show off what a good job i did of breakimg them.
  9. #84
    HSV VS Senator LS1
    Feb 2009
    Adelaide,South
  10. #85
    VS Senator
    Oct 2009
    Wanted something to do on the senator so i decided to put in some heavy duty link pins. the rubbers were starting to perish anyway so thought it would be a good time to do it. And the manual is staring to crunch abit going into third so i think that will need fixing soon
  11. #86
    VS Senator
    Oct 2009
    Went driving in the senator last night. was all good till i found a nice puddle of coolant under the car. checked it out today and found it to be the water pump. so pump is out. new one will go in tomorrow.
  12. #87
    VS Senator
    Oct 2009
  13. #88
    VS Senator
    Oct 2009
    Little bit of an update. Hopefully in a couple of weeks the senator should get some roller rockers and blue top injectors which should give it a few more kws.
  14. #89
    VS 5 Litre BT1
    Jul 2006
  15. #90
    VS Senator
    Oct 2009
  16. #91
    Demonica's Avatar
    Demonica is offline Mrs Wraith
    VS clubby
    Mar 2010
    SE Qld
  17. #92
    VY S
    Jul 2011
    Belmont NSW
    Quote Originally Posted by Clint_G View Post
    Car looks good mate real good
    ..although, why do detailers ALWAYS seem to miss washing under the guards???? it destroys the image and could look 10x better if those inner guards were blackened out
    Al
    Quote Originally Posted by showbags View Post
    Seriously dude, that threads over 4 years old. Did they give you a shovel when you joined up.
  18. #93
    VY S
    Jul 2011
    Belmont NSW
    Pretty sure youre full of sh1t, theres plenty of ppl following this thread mate....
    Al
  19. #94
    VS Senator
    Oct 2009
    Cheers for the comments guys. i should probably get the inner guards done now that you have mentioned it. i never really noticed till now. lol
  20. #95
    VS Senator
    Oct 2009
    Ok so blue top injectors are in. Also a photo of the beast just for good measure[IMG][/IMG][IMG][/IMG][IMG][/IMG]
  21. #96
    VB SL/E
    Dec 2008
  22. #97
    VS Senator
    Oct 2009
    It seams ok but i am going to get zac (drift it)to check the tune for me. will probably need to hit up the1 for a retune when the roller rockers go in tho
  23. #98
    VS Senator
    Oct 2009
    Small update. new starter motor put in as the old one was about to stop working. and hopefully the roller rockers will be installed soon.
  24. #99
    VS Senator
    Oct 2009
    So the senator is booked in to get the roller rockers installed on tuesday. Cant wait. excited to see how it will go.
  25. #100
    VS Senator
    Oct 2009
    Ok so roller rockers are installed and i had the intake manifold gasket fixed as there was leak. found out the bolts for it were all loose as was the dizzy. all good now. just needs a retune.
  1. Genuine VR 185I Senator
    By Disturbed_vegeta in forum VR - VS
    Last Post: 16-04-2011, 01:29 PM
  2. [SA] wrecking vs senator 185i
    By nasty1 in forum Parts And Other Items For Sale
    Last Post: 16-02-2010, 07:02 PM
  3. VS senator 185i or 215i?????
    By vn nut in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2009, 01:20 AM
