Page 1 of 11 12345 ... LastLast
Results 1 to 25 of 262
Like Tree17Likes
Thread: Cranky VSSSUTE 355 Twin Throttle Walkinshaw Build Thread
    dobesz's Avatar
    dobesz is offline 355ssute
    vs ss ute
    Oct 2009
    Default New pics last page, red walls etc. Comments?
    Hay guys i have been a member for a while and thought i would post my ride, a 1998 vs ss ute that i am building a 355 stroker for, plus gearbox and diff gears etc.
    I am HALF way thru the build so sorry about heaps of pics to start with lol
    FEEL FREE TO GIVE ANY ADVICE ON ANYTHING Just after a tuff every day driver. Nothing too over the top tho dont want blower or turbo etc. I know i could prob run a bigger cam but ......o well!
    I dont want a new ute but would like to be able to give them a fright!
    THE SET UP WIL BE:
    :Scat H beam 355 kit
    :Hypertect pistons
    :Stud girdle
    :Zero deck block
    :Bore and hone
    De bur block
    :Race harmonic balancer
    :new stainless valves and springs
    :Crow cam double row timing chain and gears
    :Crow pushrods
    :Match porting and light polishing nothing to over the top
    :Hardened valve seats
    :Ford style valve stem seals
    :Push rod guides
    :Yella terra street roller rockers
    :Full gilmer belt drive kit
    :Running 10.5 compression.
    :ARP bolt kit
    :Braided fuel lines
    CAM:
    SPECO Cam
    .....Timing
    .....open Close Advance @50 Cam Lift Valve Lift
    In....32......68.......280......222....298........ .492
    Ex....72.....28........280......222....298........ .492
    Lobe sep:Inlet 108 and Exhaust is 112
    INJECTION:
    :Got my self a Walkinshaw manifold with an enlarged plenum for the stroker!!!
    :Will get my com remaped on dyno.
    :Twin 70mm XF Throttles
    :Blue top injecters
    :Big fuel pump
    COOLING:
    :Alluminium radiator with over sized end tanks (prick to fit)
    :AU Thermo fans with Davies Craig thermo switch
    :Gates radiator hoses
    :Big trans cooler
    :Oil catch can with braided hoses and Speedflow fittings
    DRIVE LINE:
    :3.77 gears
    :2500 or 3000 stally
    :Bump shift
    :gear box rebuild kit
    :extra clutches
    :corvett servos
    Looking for 240kws at the rears.
    I CURRENTLY HAVE:
    :Pacemaker extracters
    :2 and a half inch into 3 inch single pipe
    :hsv chip
    :cold air ss induction
    :king springs (SL)
    :air bags
    :19 inch rims
    :ve 330mm slotted roters and ve PBR calipers on the front
    DBA gold cross drilled and slotted on the arse end
    HAS INTERIOR MODS SUCH AS:
    :Painted dash facias (colour coded)
    :White dials
    :Steering wheel, re done in blue and black leather
    :Chrome hand brake and carbon fibre gear shifter
    :VQ Caprice door trims (funny shaped door pods) with the wood grain colour coded to car
    :Chrome handles
    :Kicker pro splits running off a pioneer amp.
    :Coulson seats on the way in blue and gray leather or ve gts seats
    dobesz's Avatar
    vs ss ute
    Oct 2009
    I have a few pics of the 355 whilst it was in the build; as you can see i used the H beam Scat kit
    Has had mild head work, ls1 valve guides, match porting polishing etc Also in photo below you can see i have used a stud girdle instead of four bolt mains. Also had to have the ASR sump made custom to fit around girdle!
    Can see that i have had mild port and polishing as nothing to crazy is needed as dont want to slow the air flow down too much, or will go backwards in power!!
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Got a bit bored so me and my panel beater decided to make the rocker covers look trick and give the sump the same treatment!
    And once it was all together it looks a little something like this, should go well with the twin throttles and other billet goodies
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Because of the increased power i thought a set of ve 330mm brakes was in order for the front, as the little vs brakes just did not cut the mustard! Also when towing etc i was getting huge brake fade.
    They also fill up the rims a lot nicer and after some two pack Ferrari red they def look the goods, not to mention it stops on a ten cent piece! Have the standard rear brakes with the DBA Gold series cross drilled slotted rotters for show!
    dobesz's Avatar
    vs ss ute
    Oct 2009
    I was orig going to run the trickshift twin throttle manifold. Its a cut and shut job of the stock bananas. I didnt really like the look of a carby style manifold with a 1000cfm throttle on it.
    I was lucky enough to score a walkinshaw twin throttle body set up that had the plenum modified as it had twin gas research throttles on it. Came with no throttles or fuel rails so i am in the process of setting up throttles for it.
    When i first got it it looked like this
    looked a bit tired so had it beed blasted and thought the plenum would look nice polished. Guess it looks ok
    Still needs the lower manifold sprayed. Will be the same colour as the rocker covers. Got my self a real walkinshaw throttle body that has been shaved as they are a XF Ford throttle so lots of lumps and bumps on them from deleted vacume lines etc!
    Not running the 2nd throttle as an 80mm i would rather run the standard XF throttle. As a 2nd throttle is 80mm and is not needed, not to mention the inlet in the plenum is only 70mm as was modified!
    From this messy looking throttle to this!
    As you can see it has been dye grinded and ground, now just have to weld up holes without warping throttle body Still need to fab up linkages to operate 2nd throttle
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    She doesn't look like a Group A Manifold, The bottom runners are different an the front has elongated holes to the right of the thermostat housing an the front of the housing is a different shape.
    Curious what manifold it is tho...
    Apart from that, Nice ute
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Yea it ain't a grp a. It's a vl Walkinshaw manifold. Hence runners look different lengths.
    the one at top of pic is my manifold (vl walky) and the top one in GRP A manifold. Grp A plenum sits flat but vl sits on an angle!!!
    If u take plenum off they come thru at different lengths as u can see in photo! Also thermostat housing is in different position on grp a as it's offset to the left.
    MUNCH MUNCH LS1 4 LUNCH
    Jecs's Avatar
    Jecs is offline PAVTEK Race Engines
    '97 Caprice 355ci & Mongoose Shield Pushy
    Feb 2005
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Maybe but considering i got the manifold for under two grand i thinki did ok Not to mention it was modified to work better with a stroker as it was designed to work with a 5l. So in theory plenum should be larger for stroker!!!
    Could be worse....could have standard bananas
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Also got my self an alluminium radiator, trans cooler and twin au thermo fans running off a Davies Craig thermo switch that runs in the top radiator hose.
    Fitting of all of the above did not take too long at all, think about a day and a half as was real fussy with how the au thermo fans fitted to the radiator. Made it look like its meant to be!!! Got enzed to come out and change my oil lines as they had the threaded type that screwed on to radiator. But as was running trans cooler i needed them extended around to front of bar!
    Currently running the ss induction bigmouth cold air intake. But when i change motor will go to the GRP A air box set up!
    U can see the davies craig thermo switch mouted in the top radiator hose. U simply set the switch with a little dial that is mounted in engine bay. So u can choose at what temp the fans will click on!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Will you need to modify the bonnet to fit the manifold?
    and 3 Dangerous non ABS VN's
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Yea the reason plenum was modified was to make it bigger as you want about 1L of air to each L of engine size. The guy ran twin gas varna on a 355 and made 500horse with it! It sits a little taller than the grp a one. A vn def has to have bonnet cut as it's flatter than a Vs bonnet. But on a Vs u can get away with just cutting reo in bonnet. But because it's a little taller than normal may sit thru bonnet
    Will also have a grp a bonnet buldge for every day street use
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Got a GRP A air box off a guy who gets me lots of gear cheap, as he is a collector. But has cut and changed air outlet to side outlet to suit normal 5l. WHY would u do that considering they are worth 500 on ebay with y piece lol!!
    So i will customize it back to look like factory GRP A air intake! I figured it would be better to do it in little steps rather than shape the whole thing at once!
    So i did this to get the 90mm pipe facing in the direction i wanted it to go. Now i need to make it funnel from box into 90mm pipe!
    I cut the right hand side out with air hack and made the shape i need by using sand paper. As it holds its shape when bent!! Then i fiber glassed over the top. I repeated these steps to make the left side once fiber glass had dried on the right side.
    Gave it some shape by sanding and a little bit of bog. Has come up much better than i thought it would, inside is perfect and smooth!
    Not sure what colour we will paint it yet. Prob in a style like i did with rocker covers! As it has the raised ss logo on it so will look trick in two diff colours!
  15. #15
    Jecs's Avatar
    Feb 2005
    mate uve got a nice ute. ur doin a good job with the motor work. even tho i dont agree with some of the mods, its comin up nice.
    all those get judged by me, the king of kings..
  16. #16
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Comming up nicely mate, keep the pics comming
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  17. #17
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Jecs what mods don't u like bruz? Don't worry I will not be offended lol
  18. #18
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Got some more pics of her, not the most showy ute but its my every day driver so its not bad for that!
  19. #19
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Also got a full set of gilmers that even includes a gilmer drive for the aircon, will throw them on the new motor once it is in.
    Also got a knock sensor, chip and loom. The hsv 185s had this. Was the only diff between a stock 5l and a 185 5l. I wanted it so that when it goes in i will have a knock sensor just for a bit of added security. Altho some people dont beleive in them i think its worth while. However u cant run with a solid cam as it tends to set them off lol
  20. #20
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Hay guys should I get my box built before getting it dyno tuned or save the money and do box once tuned? Or do I need box done to tune properly?
  21. #21
    MDVXSS is offline Banned
    VXSS, VR acclaim, VS wagon, HQ One-Tonner
    May 2010
  22. #22
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
  23. #23
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Quote Originally Posted by soop View Post
    "munch munch munch, old decrepit VT LS1's for lunch"
    Yea just something I thought would stir shit up lol. Tell u the truth an ls1 with tune and otr prob will own me lol
  24. #24
    Nov 2008
    Smithton, Tasmania.
    Yeah I know.
    Quick tip, if you want to stir shit. Change LS1 to L67. The drop kicks flappy cap morons on here come howling from miles off.
  25. #25
    dobesz's Avatar
    vs ss ute
    Oct 2009
    Quote Originally Posted by MDVXSS View Post
    needs red coil packs
    Ha ha mad dog, mmmmm maybe the v8 cop chip as well lol. Thought I would throw me thread up on here and get some different opinions. I feel like a traitor lol
  1. Twin Turbo VS Ecotec Build **engine build in progress page 16**
    By IBLOWN in forum V6 Development And Modification
    Last Post: 27-12-2011, 11:57 PM
  2. [Buick] twin turbo build
    By dccbvt in forum V6 Development And Modification
    Last Post: 16-02-2011, 01:41 PM
  3. 304 Twin Turbo 185 build.
    By Denso in forum V8 Development and Modification
    Last Post: 21-07-2010, 08:08 AM
  4. Vt2ss m6 Twin Turbo Build
    By jakstas in forum VT - VX - VU - WH - V2
    Last Post: 14-03-2010, 03:51 AM
