Decicrate
OWNER: Bazil B Bonebrush
MODEL: 1996 VS 'S' Pack
COLOUR: Panther Mica
BODY KIT: Standard S Pack Skirts and rear tail
ENGINE: L67
ENGINE MODS: Ported M90 with MACE light weight rotors
Ported LIM
85MM throttle body with ADZ elbow
Ported and decked L67 Heads
Stainless Steel Over sized valves
Custom Push rods
Decked block
.020thou bore
Mains bored for alignment
Cam journals bored for alignment
Removed balance bar,
ZZP XPZ CAM
JE forged pistons with coating .020 thou over
H Beam rods
Fully balanced rotating mass
ARP Head Studs, Main Studs and rod bolts
150 PAC Springs, retainers and locks
Yella Terra 1.7 Roller Rockers
Yella Terra blower snout.
Moran 160Lb low impedance injectors
AEM peak and hold injector driver.
INTERCOOLER: Hybrid W2A. MACE A2A plate that feeds into a external W2A duel core system.
EXHAUST: Stainless Extractors Di Filiipo 1 7/8 into 2.5 inch twin pipes with twin cats into a twin 2 1/2 in and 3 inch single out Magna flow muffler into a huge 3 inch resignator to rear.
COMPUTER: Kalmaker Workshop Series (real time all the time) 3 Bar MAP
INTAKE: Custom air box, fed by a 4 inch pipe, 9 inch K&N pod filter, to 4 inch pipe from the Pod through to the throttle body.
GEARBOX: Mal Woods T56 Road Race Gearbox 022
CLUTCH: Billet NPC LS1 Flywheel and heavy duty LS1 clutch and pressure plate.
DIFF: LSD 3.45
BRAKES: 330MM slotted front rotors with VE twin piston calipers, rears are 315MM slotted and ventilated rotors with VE rear single piston calipers and a 1 Inch Master Cylinder and hydraulic handbrake. Pads are REMSA from GSL Rally Sport
SUSPENSION: Custom Bilstein coil overs with King springs and custom camber caster strut top plates at front and Bilstein rear shockies and adjustable rear springs, sill leveled, Duro 95 bushes all round, whiteline adjustable sway bar, adjustable panhard rod, adjustable caster arms, and strut brace.
WHEELS and TYRES : Road use 19 x 8 AMG Running Ventus 245/35/19 all round, Track use gutter rashed SS rims (no i didn't gutter rash them) 17 x 8 Running KUMHO ECSTA V70A R spec tyres and KUMHO V710 245/45/17.
INTERIOR: 6 point roll cage, Sparco EVO race seat, 6 point harness and an Alpine stereo.
POWER: 459 RWHP ( 56MM pulley ) and over drive balancer.
FUEL: E85
TIMES: QR Clubman Circuit 64.1, Mt Cotton Hill Climb 48.20 Drags 1/4 mile 12.97 (more to come) Lakeside 63.3
BUILD TIME: Owned the car since 1999, still an on going project.
COST: SSSHHHHH My partner can read!!!!!!!!
Would like to say a very big thank you to the following people,
Craig at Hornibrook Motorsport 07 3865 1072
Allstar Tuning Systems 07 3265 7550
Rhys at Northside balancing 0414 867 055
Mal Wood Automotive 07 4661 3548
Commodore Tuning Systems Brisbane 07 3266 9333
Some videos of what I like to get up to.
http://www.youtube.com/watch?v=bZYNrAdsoMc
http://www.youtube.com/watch?v=w6Mo5H2URqM
http://www.youtube.com/watch?v=FylhNfV6dRo&NR=1
http://www.youtube.com/watch?v=t8vqceZyws0
http://www.youtube.com/watch?v=ziCfCHu2PBM&feature=related
http://www.youtube.com/watch?v=P9aIhRgVe-U&list=UUz9PIYvjA6Vs3kr9BPbD-Cg&index=23&feature=plcp
http://www.youtube.com/watch?v=EgO5rx533wc&list=UUz9PIYvjA6Vs3kr9BPbD-Cg&index=18&feature=plcp
http://www.youtube.com/watch?v=zzjUEMksRfI&list=UUz9PIYvjA6Vs3kr9BPbD-Cg&index=14&feature=plcp
http://www.youtube.com/watch?v=MuT_8rkMIMo&list=UUz9PIYvjA6Vs3kr9BPbD-Cg&index=12&feature=plcp
http://www.youtube.com/watch?v=OqWOVFjLs7Q&list=UUz9PIYvjA6Vs3kr9BPbD-Cg&index=2&feature=plcp
http://www.youtube.com/watch?v=6k9sceg-Atc&list=UUz9PIYvjA6Vs3kr9BPbD-Cg&index=1&feature=plcp
ENGINE: L67
Ported LIM
Custom Push rods
Decked block
.020thou bore
ZZP XPZ CAM
H Beam rods
DIFF: LSD 3.45
FUEL: E85
