My 1995 Holden VS Berlina Sedan - L67, A2A Intercooled, Plus Heaps More
ben315vz
Donating Member
Tamborine Mountain, QLD
'05 Holden VZ Calais V8
Hey everyone,
About 12 months ago I had a thread on this car, but I had to remove it due to privacy reasons. Well now I decided to start a new thread and start fresh. A lot has changed on this VS Berlina in the last 12 months.
Name:
-Ben Galea.
-23.
Year:
-04/1995.
Make:
-Holden.
Model:
-VS Berlina.
Type:
-Sedan.
Engine:
-3.8L L67 Supercharged V6.
Transmission:
-T5 Manual with Exedy Performance Heavy Duty Clutch.
Diff:
-Harrop TruTrac, Standard Ratio.
Engine Modifications:
-MACE A2A Intercooler Kit.
-LS1 Throttle Body.
-60LB Fuel Injectors.
-82 Degree Thermostat.
-MACE 19PSI Boost Up Pulley.
-XP Stage 2 Camshaft.
-130LB Valve Springs.
-Rollmaster Double Row Timing Chain.
-BYE Performance Cold Air Intake.
-Blower Port and Polish.
-LIM Port and Polish.
-Machine A2A Plate.
-Custom MSD Ignition Leads.
-Relocated Coil Pack.
-Walbro High Flow Fuel Pump.
-Pacemaker Extractors.
-2x 200CPI High Flow Cats.
-Kalmaker 2 Bar MAP Tune.
-5% Overdrive Balancer.
Power:
-238.7RWKW.
-324.5RWHP.
-837.5NM Torque.
Wheels & Tyres:
-WM Caprice 18's.
-Goodyear F1 Directional 5 235/40R18 Tyres.
Suspension:
-Pedders SSL all round.
Brakes:
-VE V8 Brake Upgrade (Front).
-322mm Brake Rotors.
-VE Twin Piston Brake Calipers.
-RDA Drilled and Slotted Brake Rotors All Round.
-Braided Brake Hoses.
Interior:
-Full Leather Seats.
-Leather Door Trims.
-Statesman Dash.
-VY SS Pedals.
-SAAS Boost Gauge.
-SAAS Volt Gauge.
Stereo:
-Alpine CDE-148EBT CD Receiver.
-Alpine Type R Splits.
-Alpine Type R 6x9s.
-Alpine Type X 12" Subs x2.
-Alpine PDX-M12 Amps x2.
-Alpine PDX-F6 Amp x1.
-Kicker Wiring.
Other mods/Features:
-Factory Upgrade Alarm.
-Automatic Window Wind Up (when doors lock).
-35% Window Tint.
-Dynamat in all Doors and Boot.
-Optima Yellow Top Battery.
Future mods:
Photos:
-First Day I got my VS (24/11/2007):
-Before L67 Conversion:
-After L67 Conversion:
ben315vz
Donating Member
L67 Conversion.
-Old 3.8L Ecotec V6 out and fully rebuilt L67 and Transmission goes in:
-Few months later, after the engine was run in (so about 2000kms later), A2A install and K-Frame Spacers:
-How the engine bay looks currently:
ben315vz
Donating Member
I decided to go on Cruise for Charity 10 (10/11/2013), but first I wanted to take the VS to a spray painter and get the whole front end resprayed because of the stone chips, both side sills and rear bumper bar:
They ended up finishing it the day before the cruise! Here are some photos from the cruise:
ben315vz
Donating Member
Extra photos:
ben315vz
Donating Member
Reserved.....
GothicKidd
ლ(ಠ益ಠლ
South Australia
VR S2 Exec
Looks good, not a fan of the stickers on the enclosure..
also what's the go with the frame spacers?
ben315vz
Donating Member
Yeah that's how I bought it, someone else put them on. Will probably take them off.
Had to fit the K-Frame spacers because the supercharger pulley was hitting the bonnet, only because the A2A intercooler lifted it up so much.
woodyotoad
Queensland
Vs commodore
wow amazing work there, gives me some motivation to get my garden ornament back on the road and boosting :)
ben315vz
Donating Member
UPDATE:
On the 14/04/2014, I was cruising along and the transmission decided to go bang :( And yes it was rebuilt at one stage so I don't know what caused it to go. Anyway, ended up losing all gears including reverse.
Ended up getting it towed home and left it in the garage for a bit.
After thinking about it for a while, I was considering doing a manual conversion. I went online to see how much everything would cost and if it would be worthwhile. The day I went online to have a look, I found someone selling a VS Commodore Ute that was factory T5 Manual! And they only wanted $1400 for it. Reason being, where the pan hard rod bolts to the body, that bracket was almost broken completely off. But I still took it for a drive, it changed gears smoothly, and I was thinking that I could just sell parts off that ute that I don't need and then scrap the body.
Photos of the ute (photos that were in the advertisement):
First of all, yes I know it's rough, and no I am not going to be using that gear knob, I will find a genuine one for once it's all setup in my VS. I only wanted this for the manual conversion and because I knew it would have all the parts I need.
So on Monday (21/04/2014), I decided to start striping my VS. There are also other problems with my VS at the moment, like the heater core leaking coolant (I had it bypassed for a while), broken passenger side engine mount, so I decided to get the whole lot done while the car is off the road. Doesn't matter how long it takes because I have two other cars I can use anyway.
Today I decided to start removing the dash and center console. I'm also going to be removing all the wiring for the gauges and a few other things, and redoing it all properly. I also have a Statesman dash and center console that I will more than likely fit once it's all ready to go back together.
Leaking heater core:
So in the end it took me about 6 hours to get the engine/transmission out and 2.5 hours to remove the dash and center console. I have done it all by myself and I have never removed a dash before. It seemed fairly easy and straight forward and didn't even use the workshop manual. But I will be looking at the workshop manual to work out how to remove the heater box and heater core later.
Due to financial reasons, I won't be doing much more to my VS for a while. I have most of the parts, but there are a few things I need to get (like clutch kit, flywheel, heater core, engine mounts and other things I want to do to the engine), and I can't afford it right now. But I figured that I can't drive the VS how it was anyway so I may as well slowly do some work to it and will buy what I need as I can afford it.
ben315vz
Donating Member
Every time I look back at the photos of my VS it keeps motivating me to keep going with it :) Everything I have done has been worth it though, even though there have been a few ups and downs. Not going to give up on it.
