hey i recently got my radiator replaced and now all my air conditioning does is cold air.. the cold works perfectly but when u turn the knob thing to heat it doesnt work just still pumps out cold air.. is there a simple explanation for this.. thought i would ask before i pulled my dash apart again since its hardly sitting right since last time..
any help would be appreciated
thanks
Try asking this in the VR/VS forum. You might get a little more help. This is the my ride section. Your problem may be the temp selector not connected up properly. Easy fix. Have a look down near where your left foot sits when you are driving. Move the temp control and keep and have a look. You should see a metal rod moving back and forth as you move the temp control. It should be attached to a lever. If it is not, thats your problem, just needs to be reconnected. Have a look and let us know. As the question again in the VR/VS forum and you will get the help you need.
