View Poll Results: Idle Problems may be caused by
Voters
2. You may not vote on this poll
  • Air Sensor
    0 0%
  • Other Sensor
    0 0%
  • ECU
    2 100.00%
Results 1 to 5 of 5
Thread: VR Stroker Auto Idle Problem
    VR 5.8
    May 2007
    ACT
    Angry VR Stroker Auto Idle Problem
    Problem: Intermitantly the engine sticks on a 1500 or 2500 RPM idle without any visible reason.Throttling the motor to drop the revs does not work and infact makes it worse.The engine is 50000KM old and has always had a 1200 rpm idle when cold but settles down to 1000 RPM when warm.The last time it happen i opened up the throttle all the way and then the engine settlted down.Yesterday in a warm state opening the throttle up caused the engines to lock into a 2500 rpm idle.Does anyone have any ideas.Help
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    id take your throttle body off completely and give it a good going over with some carby cleaner man. make sure the butterfly isnt sticking at all and also give the IAC valve and the ports for the vacuum and IAC a good clean too.
    thats your first thing to do to rule out any problems there.
    Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i'll go with sircruise and say that you need to look at the TB and IAC. possible the IAC sticking fully open. a can of crab cleaner should hopefully sort it out
    Body by Holden, Soul by Brock
    the Legend will live forever
    vs ss stroked
    Jan 2012
    qld
    i had a similar problem a couple of months ago,and it turned out to be the stage 4 chip i had put in was in back to front,
    i'm not saying this would be ur problem but if u have had a eprim put in your memcal it could be the problem!!!!
    L67 Calais's Avatar
    L67 Calais is offline Donates His Member
    VS CALAIS Series II Supercharged L67
    Jul 2008
    Andrews Farm, SA
    WOW!!!! A 5 year old thread Dig! Mammoth Troll effort mang!!! lol
    MY WEAPON: http://forums.justcommodores.com.au/...ng-10-psi.html
    NEED 3.9 or 3.7 DIFF GEARS, PM ME IF YOU KNOW OF ANY
    Quote Originally Posted by wraith View Post
    Mace spend time and money developing a good product and making sure there's gains to be had. Backyard mechanic wants to make wood blocks. Discuss.
  1. VN V6 idle problem
    By Webster_140db in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2006, 11:04 PM
  2. Vn Idle Problem
    By Doolang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-08-2005, 12:14 AM
  3. Idle problem
    By LYRIC in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-07-2005, 04:24 PM
  4. Vn Idle Problem
    By keatz_RedVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 06:25 PM
  5. Vn V6 Idle Problem
    By jackus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2003, 07:12 AM
