Results 1 to 2 of 2
Thread: Vr V8 - Stok-8
    VR V8 BT1
    May 2006
    Default Vr V8 - Stok-8
    This is me commodore its a VR V8 Exec BT1 (Ex-Chaser) and specs are as follows...
    Block has been Decked, Acid Cleaned, bored and honed + 20 Thou.
    ACL Race Series Bearings and Rings.
    ACL Race Series Flat Top Pistons.
    Pacemaker extractors wrapped in exhaust wrap.
    2.5 twin exhaust system with a highflow cat and muffler on each pipe.
    Crane camshaft 284 Fireball
    Stage 2 shift kit & Corvette Servo
    Transcooler.
    Bigger Radiator with AU Twin Thermo's.
    Tightend LSD Diff 3.55 Ratio
    Fe2 suspension
    VY Twin Piston Brakes with police spec pads.
    Torque Power Dual Plane Manifold
    EFI Hardware 1000cc Throttle Body
    Blue Top Hi-Flow Injectors
    Pro-Comp High Performance Distributor
    Pro-Comp High Performance 9.5mm Ignition Leads
    RPM USA High Volume Oil Pump
    Rollmaster Double Row Timing Set
    Stainless Steel Roller Rocker Kit
    Powerboss Hydraulic Lifters
    L34 Tuffridded Valve Set
    Speed-Pro Chrome Moly Pushrods
    Speed-Pro Valve Springs
    Performance Crane Cams Valve Locks
    Heads Ported and Decked.
    Electronic Automotive Custom Dyno Chip (Need re-tuned)
    Think thats it engine wise other stuff includes VY GTS Bodykit
    Monaro Bonnet (Not on yet, LAZY!)
    17 Inch Racing Dynamic Rims
    SS Seats and Trim
    Elextric everything.
    Will post dyno sheet once i get my car in the workshop and get a new custom chip done.
    Attached Thumbnails Attached Thumbnails Vr V8 - Stok-8-november-2006-1.jpg   Vr V8 - Stok-8-november-2006-2.jpg   Vr V8 - Stok-8-november-2006-3.jpg   Vr V8 - Stok-8-dsc00081.jpg   Vr V8 - Stok-8-dsc00082.jpg   Vr V8 - Stok-8-dsc00083.jpg
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Looks good mate. Nice amount of engine mods, should put out some nice power.
  1. My bay VR V8 = STOK-8 :)
    By mattakaspeeedy in forum VR - VS
    Last Post: 01-12-2006, 01:02 PM
