Come Racing 4.2L stroker kit
Ported and polished heads
Forged Wisco pistons
Come Racing con rods and rod bolts
Crane hydraulic roller lifters
Custom ground hydraulic cam
Machined
Wolf 3D custom made ECU
GT35/40R Turbo
50mm external wastegate
50mm blow off valve
600x300 front mount intercooler
Custon Alloy intercooler piping
Custom steam pipe Manifolds
3" custom exhaust from turbo back
High flow cat
T700 gear box fully rebuilt
Stage 3 shift kit
3000rpm Stall Converter
18" VY SS Rims
Huge Stereo
nice car mate, how much RWKW? how much boost? and should get some vids![]()
Awesome work on the turbo set up mate. Would be interesting to see some power figures.
nice man thats what i was gonna do to my vr, but after seeing all the things that went on my brothers vs im thinking other wise lol
350rwkw is a big ask especially only runnin 9psi, i be thinking yoou will be needing to wind the boost up a fair bit to be reaching your target. Just a rough guide I know a guy who has built up 4.2L ecotec running 10psi without the i/c and his only pulled around 230rwkw. It does have incredible torque and absolutely flies.
Nice work though mate it will be a weapon and you deserve to be proud of your efforts.
i think he meant after its run in and at a higher boost
yeah i realise this hence why i said a fair bit. I am thinking well over 20psi will be required, I was just trying to give people a rough benchmark.
Should go over 300rwkw easy as you like, good turbo, good pipes. I'd put money on it![]()
Yeah it looks sweet mate
Some extreme pipework in there mate, sounds like you did everything right, im sure it will give you the output you wanted int he end.
Did you drive it before your turbo'd it? I have always been interested so hear how 4.2 litre stroked 6's go without any other major mods........
Originally Posted by wikky
Nnnnnnnnnnnnnice!
usually turbo cams have a bit of overlap to help scavange the exhaust gases, if thats the case she should sound pretty darn nice. but even a turbo on a standard motor totally changes the note.
It looks like a very well designed and made setup. should be nice and reliable and give you big numbers. i wish i could afford a BB turbo!!
