Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
Like Tree2Likes
Thread: Jarrods VR S
  1. #26
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    How much you get it for?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  2. #27
    spauldj308's Avatar
    spauldj308 is offline S Pack Man
    VR S sedan 5L, VSII ute
    Oct 2005
    Hobart, TAS
    $2500. Doesn't have seats, but pretty happy with it.
    VR II S sedan - Genesis Blue - Cammed 304 - T5 - 19's - Weekend warrior
    VS II S ute - Diablo Red - V6 - Getrag - Daily Hack
  3. #28
    VS Senator
    Oct 2009
  4. #29
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    The motor will be pulled out in the next few days, hopefully in and running by Christmas
  5. #30
    VS 5 Litre BT1
    Jul 2006
  6. #31
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    Small update:
  7. #32
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    Pedal box, loom and dash all pulled from donor car. Just got to pull out the diff, rear suspension, fuel tank, tailshaft, carpet, doors, bootlid and the shell can go for scrap. That will all be done Friday, then it's on like donkey kong!
  8. #33
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    Going..
    Going..
    Gone!
    Farewell, old friend..
    When the shops open again, ordering a cam for the 304, looking at a Crane H276. Matching it up with a Rollmaster adjustable timing chain and a Chiptorque tune.
  9. #34
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Good work mate. You cleaning up the engine bay at all or leaving it stock? I just tidied mine up left looking very close to factory when I did mine. Keep us posted with the updates.
  10. #35
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    I'm just going to clean it all up for the moment and get it running, not go too crazy. Once it's all run in, I might look at hiding wiring and all that fun stuff.
  11. #36
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    Progress:
    Welch plugs changed, new seals and gaskets throughout, new water pump, Exedy HD clutch in. Extractors in, steering rack in, alternator on and hooked up, a few other bits of wiring in.
    A bit behind where I wanted it to be, was given the wrong clutch by the local parts store. After they supplied me with the wrong cam.
    Aiming to have it going by April 6, would make a hell of a birthday present.
  12. #37
    Oct 2011
    Awesome as man… Yes indeed it would be a really good birthday present haha Conversions never go to plan lol i just did a buick to ecotec in my vr and didnt go to plan at all.. eh it will be worth all the time n effort when your done keeping a eye on this.
    IF ITS GOT TITS OR WHEELS ITS GONNA COST YOU.. ESPECIALLY IF THEY ARE BIG TITS AND BIG MOTORS
    MY DAILY NOW WITH ECOTEC CONVERSION
    http://forums.justcommodores.com.au/...ml#post2145177
  13. #38
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    First startup:
    VR V8 Conversion - First Start - YouTube
    Borrowed an ignition module off a mate, tickled the timing and it was off. Wouldnt keep going though.
    Hooked up the rest of the exhaust, the tailshaft, the radiator and all the rest of the fun bits, filled it up with water and...nothing. Cranks, but won't fire.
    Hooked a noid light up to the injectors, no pulse. We swapped out the BCM/keyhead, no difference, but the dash lights stayed on. So that was changed back.
    Checked error codes - got a Code 31 - Theft Deterrent Signal missing. So, unless I can figure out a way to bypass it, I'm going to try to get the immobiliser programmed out of the memcal, and put an aftermarket unit in at a later date. Bit frustrating. We had it running for just long enough to bed the cam in.
    Hopefully it get sorted soon, I'm itching to drive it.
  14. #39
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    Ok, sent away the memcal, had the immobiliser tuned out, all good now.
    Got it back after the roadworthy and wheel alignment - thats the only reason its on the 16s. Looked ok, but the 19s are back on now.
    Sorry abut the filthy car, and the iPhone pics, but here it is in all its glory;
    Still have to rewire to foggies, re gas the AC and weld some tips on the exhaust, but I'm stoked. Havent been able to stop driving it.
    I'll try to get some better pictures tonight.
    WHY DIDN'T I DO THIS YEARS AGO?
  15. #40
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Looking good mate. Why did you get the immobiliser tuned out? Mine was fine, the BCM reads the key not the ECU. The ECU just gets a signal from the BCM once the BCM recognises the key and accepts to.
  16. #41
    spauldj308's Avatar
    Oct 2005
    Hobart, TAS
    That didn't work for me. I tried swapping the BCM and the key head over from the SS, no love. That just gave constant power to the dash lights. Swapped the BCMs back, tried the spare key. Whatever I did, it threw a Code 31, which is 'Theft Deterrent Signal Missing'. As soon as I got it tuned out, it ran and has perfectly since. It has an aftermarket alarm and immobiliser, so it's no big deal.
  17. #42
    VS 5 Litre BT1
    Jul 2006
    Nice work. Welcome to the 5 Litre club !
