Results 1 to 4 of 4
Thread: VS Calais Starting problems...
    vs calais eco
    Sep 2006
    Disney land!
    Question VS Calais Starting problems...
    For the last couple of months now the calais has had problems starting, like when you turn the key nothing happens (like the batterys dead or something) i used to have to sit there for 5 mins turning ignition on/off on/off untill the pos would work! But now i think ive found something thats linked with the problem, when i press the unlock button on the key head (after already unlocking doors and sitting in car with key in ignition) if i press it once or twice she fires up no worries! Im thinking maybe the actuator in the door might not be working properly or something and causing the imobiliser to stay on, and it takes a few prods on the unlock button to let it know the doors are unlocked? any thoughts please??
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    This is the my ride thread.
    the section your after is further down the main page.
    also it sounds like the contacting ring between your keyhead and ignition may not be working properly.
    vs calais eco
    Sep 2006
    Disney land!
    Quote Originally Posted by Haydz View Post
    Bugger, half blind
    I wouldn't of thought that would of made a difference, but will check it out none the less! Cheers mate
    vs calais eco
    Sep 2006
    Disney land!
    checked the key and it connects fine with the terminal! still have this issue, anyone else got some ideas or had similar problems??
  1. Problems starting VT
    By VT00 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2009, 08:59 PM
  2. Problems with Starting
    By Ianm1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-01-2008, 11:03 AM
  3. vr vs calais starting problems
    By Peter4690 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-12-2007, 12:50 AM
  4. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  5. vn starting problems
    By driver in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-08-2005, 09:42 PM
