Results 1 to 6 of 6
Thread: Air con only works on high
    VX II Calais
    May 2009
    West Sydney
    Default Air con only works on high
    Hi all just pickked up my VXII Calais and the air con only works wen the fan speed is at MAX. Whats causing this and is it an expensive fix?
    Cheers Frank
    accentstencil's Avatar
    accentstencil is online now Donating Member
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Since you have climate control I'd say that it is a faulty Ventilation Motor Control. I have no idea about the cost to fix it but I don't think it would be real expensive.
    MY RIDE
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Not sure if its the same part as Accentstencil is referring to but the most likely problem is the amplifier. This is the component that regulates the fan speed. Your symptom is typical of a faulty amplifier. Should be located somewhere behind the glovebox just to the right and slightly above the blower fan. Cost around $70, retained by two self tappers. Only takes a few minutes to remove (if it's in a similar position to the VY as described above) and the damage will be obvious once you see it.
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by Calaber View Post
    Yes, it is the same thing I think, my manual refers to it as the Ventilation Motor Control.
    MY RIDE
    VX II Calais
    May 2009
    West Sydney
    Is this only available as a Holden genuine part?
    5.7L VX II Calais ,Tungsten,Vy SS Rims,Full cream leather,Twin,2.5" Redback Catback,Pacemaker 4 to 1's,5% Tint,Chromed Grille
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    I can't advise you on that. I purchased mine there and it is made in Aus by a supplier to Holden. You could ask an auto sparky, but I thought the price was reasonable from Holden anyway.
  1. nothing works
    By bigneilsen in forum Car Audio
    Last Post: 25-10-2008, 09:46 AM
  2. Climate control fan only works on high
    By kerb2kerb in forum VY Holden Commodore (2002 - 2004)
    Last Post: 16-07-2008, 06:58 PM
  3. VX headunit works and doesen't works
    By kaishiz in forum Car Audio
    Last Post: 13-09-2007, 01:38 PM
  4. Who works down here
    By Dayvo in forum The Pub
    Last Post: 25-03-2007, 06:51 PM
  5. Air Con only works on high
    By Global in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2006, 10:45 PM
