Results 1 to 4 of 4
Thread: mainifold torque specs
    Vx S pack m5
    Sep 2007
    keilor down, vic
    Default mainifold torque specs
    gday. Just replacing my inlet manifold gasket and need to know the bold torque specs for the lower manifold (one that bolts up to the head) and also the upper inlet manifold (the one on top) Also between my upper and lower manifold I'v got a metal gasket there whereas most people have a rubber one whats the go with this? can it be reused?
    thankyou
    Hot-Rod's Avatar
    Hot-Rod is offline SuPaFlY -LiV3 Surviv3 Di3
    VX Commodore Series 2
    Sep 2005
    Oz
    Thats correct, its metal, shouldn't be rubber? The seal between upper and lower manifold.
    LOWER INLET MANIFOLD 12- 18 Nm
    ATTACHING BOLTS
    UPPER INLET MANIFOLD
    ATTACHING BOLT
    TORQUE SPECIFICATION
    10 - 14 Nm
    Vx S pack m5
    Sep 2007
    keilor down, vic
    ohok by looking at this guys thread http://forums.justcommodores.com.au/...commodore.html it looks as though he has rubber oring type seals? my manifold gasket set I got also has this type and not the metal type. Can you reuse the metal gasket?
    thanks for the torque setting mate
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    always buy new gaskets, saves going back later
LinkBacks (?)
  1. 05-06-2009, 08:27 PM
  1. HELP>>>V6 engine torque specs.
    By underthepump in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-01-2010, 08:47 AM
  2. constant velocity joint torque specs
    By LisnM8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2008, 11:11 AM
  3. head bolt torque specs?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-09-2006, 10:15 PM
  4. High torque or chip torque memcal for vr v6 4 sale: $150 ono plus standard memcal
    By Youngblood in forum Swap / Wanted to Buy / Trade
    Last Post: 22-05-2006, 06:28 PM
  5. High torque or chip torque memcal for vr v6 4 sale: $150 ono plus standard memcal
    By Youngblood in forum Parts And Other Items For Sale
    Last Post: 18-05-2006, 02:54 AM
