Results 1 to 22 of 22
Thread: Idle all over the place
    -Michael-'s Avatar
    -Michael- is offline Ooh Yeah.
    VT S Pack
    Oct 2008
    Default Idle all over the place
    hey guys
    took apart my dash to fix up my stereo and now my car idles like shite.
    as in, turn the key on a warm or cold day and sometimes it'll be right and sometimes it'll drop to like 600rpm, then 500rpm then stall.
    also when i drive it and then come to a stop in neutral it stays at about 2000rpm and then take maybe a good 5-10 secs to go to normal.
    ran carby cleaner in the throttle body and injector cleaner in the tank and still doesnt fix it.
    help?
    danja's Avatar
    danja is offline Swerves for gay koalas
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Try cleaning you IAC?
    Seems unlikely taking the dash apart had anything to do with it, I reckon it's just coincidence.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    -Michael-'s Avatar
    VT S Pack
    Oct 2008
    danja's Avatar
    Jan 2006
    Quote Originally Posted by -Michael- View Post
    so just take the TB off and clean it thoroughly?
    You can take the IAC off the TB and clean it separately. They get gummed up and sticky, so that could explain why your idle takes a few seconds to settle.
    Some people say try not to get too much carby cleaner in the IAC. I've done a couple and just sprayed it right in there, watching all the gunk come out and let them dry out a bit without problems, but do so at your own risk
    VZ Exec Wagon 2007 3.6L
    Sep 2008
    Broken Hill NSW
    the idle speed motor on the throttle body might be worn or dirty, as said before take it off and give it a good clean. i used kero.
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    Hi michael, there is a vacuum hose that goes from the throttle body, to the behind the dash, now the vacuum hose if disconnected can cause idling issues.
    i would find out where it is disconnected reconnect it and you should be right. but if not then i am stumped.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    hey guys
    took apart my dash to fix up my stereo and now my car idles like shite.help?
    Check vacume hoses behinde the heater (hot/cold) switch..
    VY one tonner / gen3 / 6speed
    Jan 2009
    just left of hell
    Find the vacum supply for the dash at the engine end and block it off, see if it makes any diff before you go pulling the dash apart again.
    vt ss
    May 2009
    I know its a pain but disconnect the battery for a couple of mins let the computer reset start it and rev it to three thou for ten secs to reset the iac valve. If this fails id be looking at a vacuum hose near heater controls but you can normally hear them hissing if they are off.
    -Michael-'s Avatar
    VT S Pack
    Oct 2008
    Did everything everyone says and most of the time it idles good but sometimes like this morning it drops the revs off till it stalls. and its not like it was cold either.
    so i just give it a blip of throttle and its fine. sounds like maybe not getting enough fuel when its just been sitting there or something :/
    fitz_vt's Avatar
    Nov 2008
    you need a new fuel filter and probably have gunky injectors, clean the injectors and replace the fuel filter, if this does not work then i would say its the fuel pump. if not then i would call out a mechanic because thats not right. it shouldnt idle all over the place, does it have any engine noises? like a rapping noise, a tick noise.
    -Michael-'s Avatar
    VT S Pack
    Oct 2008
    yeah I thought filter but i can run it for hours on a cruise and it's got all of its power.
    Just does it once and it you give it a good kick then its all good
    fitz_vt's Avatar
    Nov 2008
    yeah injectors might be the go. i would run some injector cleaner through
    -Michael-'s Avatar
    VT S Pack
    Oct 2008
    Already done that though..
    took the throttle body off and i'm cleaning it with carby cleaner...
    WOW its like black sludge in there o.O
  15. #15
    daggett is offline Crazy Tiger
    Commodore S VT Series II M5 & VT II Wags
    Mar 2004
    Goulburn
    I'm voting for the vacum hose. wow when thats fixed what a difference it makes
  16. #16
    VSII Calais supercharged
    Mar 2005
    South Coast, NSW
    Have you checked for an error code yet? I had a similar problem where just out of the blue it would idle at 2000rpm. I got an error code and when I looked up the code it was a faulty TPS or throttle position sensor (located on the throttle body). This may not be your problem but at least check for error codes first.
    Car theives should be treated just like horse theives and cattle rustlers in the days of the wild west... Hang them!
    Don't be stupid. Power isn't measured by the size of your tacho
  17. #17
    Baldric is offline The BOSS
    VE GTS M6
    Dec 2003
    no ones played with the tune recently ?
    ___________________________________
    Car: 07 VE SSV 6LTR L98 A6
    Metalic Silver
  18. #18
    -Michael-'s Avatar
    VT S Pack
    Oct 2008
  19. #19
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Nah man the IAC is the one u can clean
    Once TPS is playing up gotta buy a new one
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
  20. #20
    VT Executive S1
    Sep 2008
    is the TPS something I can clean or does it ned replacing?
    i bet 10,000 dollars baised on the description that its the vaccum hose, ive had this exact problem, was skitzing out because i haddent touched the engine and all of a sudden the case was shaking, ideling like crazy and the engien light coming on before stalling. the vaccume host fell out of its boot somehow
  21. #21
    -Michael-'s Avatar
    VT S Pack
    Oct 2008
  22. #22
    fitz_vt's Avatar
    Nov 2008
    FIXED!
    this was unplugged lol
    just saying....... thought it was a vacuum hose lol.
  1. best place for a sub is.....?
    By 666vt in forum Car Audio
    Last Post: 28-10-2008, 01:19 PM
  2. Where to place sub/s in a vr??
    By Haydz in forum Car Audio
    Last Post: 25-11-2007, 11:50 PM
  3. The best place to get a RWC done?
    By Dragz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-09-2007, 03:38 AM
