Results 1 to 16 of 16
Thread: need urgent help or advice
    vt
    May 2009
    Default need urgent help or advice
    i got blown head gasket so i starting to pull everything apart
    this is what's inside inlet manifold looks like
    oil mixed with coolant
    the car broke down once then i refilled the radiator trying to drive it home
    so now the engine has knocking sound at high rpm
    please guys i really need a quick advice whether i should go ahead with recondition the cylinder head and new gasket or does it requires full engine engine recondition ?? anyone has the same problem like mine?
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    That is what coolant in oil looks like.... firstly fix the head gasket, as it separates coolant channels from oil channels.
    i would also flush your engine trough (wouldn't have a clue what with never had to flush out an engine)
    Once that is fixed test drive and confirm that it was the head gasket.
    If the knocking noise is still present, it probably means that a Bearing is becoming dry and noisy.
    To Diagnose Connecting Rod Bearing Noise
    whilst test driving the vehicle, whilst at 60 or when the engine is under load you will head a sharp rapping or knocking noise.
    Connecting rod bearing noise should be rectified very quickly as it can cause an engine seizure, replacing the Connecting rod bearings is a task to do whilst the heads are off the engine as they connecting rod comes from the Crankshaft to the Pistons. the bearings at the Piston head create noise.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    VZ SV6
    Oct 2008
    Newcastle NSW
    Often a head gasket can cause water to get into the bottom end of the engine, causing rapid deterioation of one or more big end bearings... it wouldn't be instant, however if the HG had been leaking for a bit before it was discovered certainly possible. Confirm what the knock is first... a 2nd hand motor might be a better bet then fixing this one, then discovering the entire thing going bye bye a few months down the track having spent money on it.
    vt
    May 2009
    so guys think the knocking sound is definately coming from piston and connecting rod?
    or by flushing the engine and replace head gasket would fix this knocking sound before i continue because i reckon whole set new gasket would cost me around at least 100 right before i continue
    sry this is my first time trying to replace gasket on hot rod engine and i need a clue
    vt
    May 2009
    so the progress so far
    first, i m having problem removing this fuel hose
    we have to have use quick release tool no 7370 lol, anybody know wher i can buy it from?
    for expert, where can i find tdc mark on this crankshaft lol
    on the manual it doesnt state that i have to check tdc when removing the cylinder head. is this sound right?? sry i m newbie
    vt
    May 2009
    fitz_vt's Avatar
    Nov 2008
    good on you your getting there
    TDC marks arent required on the outside. as its a remove the timing cover to re time.
    vt
    May 2009
    thanks fitz_vt hehe
    i havent had much experience with hot rod .. ups i mean push rod engine
    VX lumina
    Apr 2007
    Callington SA
    Good on you for having a go.
    Just remember to take things nice and slowly so as not to bugger anything up!!
    fitz_vt's Avatar
    Nov 2008
    Quote Originally Posted by garywg View Post
    exactly because the last thing you want is to stuff up your engine. but the timing is the most important thing if you pistons are off by a small amount you can do damage to your push rods and also cams and lifters. So when you have taken the head off be really careful re attaching it and other items of interest.
    executive vt 5.0lt
    Feb 2005
    west suburbs
    Quote Originally Posted by mitmit View Post
    how did you go with the hose did you need the tool
    vt exective
    Oct 2006
    vt
    May 2009
    update.... i m having trouble removing left hand exhaust manifold lol
    trying to figure out how to remove the oil dipstick tube from the engine so i can have access to the exhaust nut
    can someone give me a hint?
    Quote Originally Posted by gungazza View Post
    yep, i bought the complete set for $30 from autoone
    just mention what you need and they would understand
    hehe true
    it has been 2 days and this is what i have done so far
    vt
    May 2009
    just finished cleaning my RH cylinder head and it is not clean as new
    but it would be close to new when it put the cylinder head back tomorrow
    my filthy LH cylinder head
    it looks like there is nothing wrong with the head gasket lol
  15. #15
    fitz_vt's Avatar
    Nov 2008
    The head gasket might of just become dislodged but its still best practice to replace the head gasket, and if that does not work then you would be looking at a new head, better yet just replace the whole lot. as there might be other damage
  16. #16
    vt
    May 2009
    thanks fitz
    i still cleaning up the head and placing all the valve seal
    i still not sure where the noise were coming from. Hopefully wasnt coming from the bearing or it maybe only the valve lifter noise since water mixed up with oil and was over the maximum level on the dipstick at the time
  1. need urgent advice
    By shonky12 in forum The LAN Lounge
    Last Post: 25-07-2008, 10:46 AM
  2. Advice needed URGENT
    By GMBanisher in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-03-2008, 08:20 PM
  3. Urgent Advice Needed!!!
    By milesvs96 in forum General
    Last Post: 23-02-2008, 10:34 PM
  4. Urgent Advice - How to change a bumper!
    By GDSGFT in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2006, 11:29 AM
