Results 1 to 6 of 6
Thread: suspension replacement VU SS
    Pete SS's Avatar
    Pete SS is offline Resident Pomme
    VU SS M6
    Oct 2008
    Sydneys East
    Default suspension replacement VU SS
    Hi guys, I need to replace the suspension on my ute as the person before me changed the standard springs for ultra lows but left the standard shocks and now they're leaking.
    Does anyone have any hints or tips before I start?
    Cheers, Pete.
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    You will be best with some shortened shocks, Ultima or Monroe do them.
    You may need spring compressors when replacing the front shocks. The rears should just about fall out with the shocks out and the body lifted. Might be a good idea to replace the front strut top bushes as they commonly fail, especially with lowered springs.
    Other than that...it's pretty straight forward. Good luck!
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    ^^^ You will definately need spring compressors to do the front... I have never been able to change from springs without them...
    When I had sssl rears I got some pedders big bore shortened shocks. Pricey @ 300 bucks for the pair but well worth it.
    Good luck mate.
    P.S.
    Remember to take the handbrake off when doing the rear... I've had a good laugh at mates on several occasions trying to change rear springs with the handbreak on... probably not so much of an issue with the shocks.
    Once I managed to change a rear shock on the side of the road with no jack so they are nice and easy really.
    VZ AWD One Tonner
    Jul 2006
    Will definitely need shortened shocks. I'd be going KYB in the front, and a big bore 60mm Oztec in the rear (KYB don't do rear shortened shocks for ute).
    Front KYB's are $138 each, and $120 each for the rears.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Pete SS's Avatar
    VU SS M6
    Oct 2008
    Sydneys East
    Cheers for the replys.
    I've seen the shortened monroe shocks with the super low springs on ebay so I think I'll get them. How much lower than standard SS height are the superlows?
    In the Haynes manual it says to remove the CV joint from the outer hub so the control arm can be lowered enough to remove the spring - is this nessesary? Surely I could use the spring compressors to help here?
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    SL it about an inch lower than fe2 i think... fe2 being standard SS height.
    Are wel talking about the back there? with the CV joint?
    If so... spring compressors will do the job... I've swapped rear springs on anything from a VT Clubby to a VY maloo and never needed and more that to raise it, releease the handbrake and use spring compresors to get the fe2 springs out.
  1. standard suspension replacement
    By cewing in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-05-2009, 12:12 PM
  2. 4CH Amp Replacement
    By Darren in forum Car Audio
    Last Post: 04-10-2007, 08:04 AM
  3. dif replacement?
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2005, 04:36 AM
  4. Q: Diff and suspension replacement costs
    By Custom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2005, 11:41 AM
  5. Cat replacement
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-07-2005, 02:01 PM
