Results 1 to 5 of 5
Thread: Front Strut Bolts
    VT 5.0 Calais
    Apr 2009
    Default Front Strut Bolts
    Howdy,
    Do any of you guys know the size of the bolts holding the front struts. There are a pair at the bottom of the strut and need to be replaced if the strut is pulled.
    Planning on replacing the bearings at the top of the strut on the weekend and need to pick some replacement bolts up.
    Hopefully this stops the squeeling noises.
    Cheers,
    Phil
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Not sure on that one...why not just call up spare parts at your nearest dealer?
    You may not even need to remove them to get the top bushes/bearings out and in. There was a tutorial on how to do this on the Australian LS1 and Holden Forums I believe.
    SweetWagon's Avatar
    SweetWagon is online now booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Quote Originally Posted by Phil257 View Post
    Howdy,
    Cheers,
    Phil
    From memory its a 19mm bolt with a 22mm or 24mm nut
    VT 5.0 Calais
    Apr 2009
    Cheers for that, I'll try and do it without removing the lower bolts if it looks easier.
    vs commodore V6 S2
    Nov 2006
    maryborough QLD
    they say to replace them but i never did and i took them off heapos of times due to faulty struts/bearings etc.....and now i have to again cause of a brand new strut that is faulty and causeing killer knocking noises lol
  1. [NSW] WTB: VR-VS lowered front strut
    By bittsa in forum Swap / Wanted to Buy / Trade
    Last Post: 12-01-2009, 07:00 PM
  2. Flyweel Bolts S1 (6 bolts) How Do i Remove? Reverse or Normal?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:54 AM
  3. vb front strut
    By linejockey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-10-2008, 03:48 PM
  4. SA - VS front strut brace
    By SKNOT9 in forum Parts And Other Items For Sale
    Last Post: 12-08-2008, 07:48 PM
  5. Front Strut Removal
    By Spinksy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2004, 08:01 AM
