Results 1 to 5 of 5
Thread: VT Commodore V6, won't start and Back fires
    VT Executive Sedan S1 Manual
    Nov 2006
    Default VT Commodore V6, won't start and Back fires
    I’m hoping someone can point me in the right direction in rectifying the following problem with my VT Commodore, 5 Speed V6.
    I was driving home on a mild dry day, after getting out of work early. Whilst in idle at a set of lights, my car seemed fine, on putting it into first gear and beginning to accelerate, my car suddenly felt like it went bang.
    I t coughed and splattered and manage to idle for about 20 meters then died, I tried to turn it over and the car back fired, several times. Also un-burnt fuel smoke appeared in my air cleaner box.
    Engine sounds fine, no noises. Fuel pump and oil pump working.
    I called the RACV, $166.00 later. The mechanic tells me, ummm not sure. What or why !!!
    You need a tow truck, no surprise here.
    I have replaced the coil pack in the past with a S/H unit, because one of the coils collapsed, I’m wondering if it’s the coil module.
    Can anyone out there give me some ideas, I also have the genuine workshop manual on CD, where to look would be good.
    kart_racer is offline Races karts
    VT Acclaim 5M
    May 2008
    Nov 2006
    fitz_vt's Avatar
    fitz_vt is offline Pass Me A Wrench.....
    VT Commodore SII Olympic Edition
    Nov 2008
    Adelaide - South Side
    normally when these things go there are no noises, no warning signs, no nothing, the RACV mechanic doesnt sound very good, i would probably clean the injectors first and the coil packs second but then if this doesnt work you need to check a few things first to check for signs of gone gaskets.
    do you have coolant in your oil (check the dipstick for a milky substance).
    if you do have coolant in your oil you have blown a head gasket, if not then you might have blown a intake manifold gasket. or rocker cover gaskets might be gone.
    |VT Olympic Edition 3.8L Ecotec | VY S Pack Green Interior|
    Mods to come | VY Map Reading light/Sunnies Holder|
    "Give me a minute, I'm good. Give me an hour, I'm great. Give me six months, I'm unbeatable."
    '99 VT Calais
    Aug 2008
    When I had a similar problem, I replaced spark plugs and leads, cleaned injectors and replaced pressure regulator. It only got a little better but far from solved. Funny thing, it happened more often when the engine was hot.
    Bottom line, it was the fuel pump not having sufficient pressure. After replaced, it all went back to normal. Try checking it with a pressure gauge.
    '99 Chevrolet Omega CD
    (Holden Commodore VT Calais)
    ECOTEC 3.8 V6 AT - Blue Bermuda
  1. Victorian Bush Fires
    By Trayner in forum The Pub
    Last Post: 04-03-2009, 04:59 PM
  2. problem starting car, keeps ticking over but never fires
    By Caprice5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-09-2007, 07:44 PM
  3. back fires
    By raptor666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-05-2006, 09:08 PM
  4. vp fires up then dies
    By tonykt47 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2006, 04:14 PM
  5. LPG VX front fires, destroy's airbox
    By letemlaf in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-04-2005, 12:04 AM
