gsmrobinson
VT BLOWER FAN
REMOVAL
1. Open glove box
2. Using a large flat blade screwdriver pry the black pin, found inside the left hand side of the glove box, out.
3. Remove the glove box by pulling slightly to the driver’s side and out.
4. Remove 5x screws from the glove box surround trim on the left hand side of the glove box area.
5. Remove glove box surround trim, should just about fall out.
6. Remove 2x screws from inside the ½” holes located at the left hand side dashboard door duct trim on the left hand side of the dash.
7. Remove 1x screw on the same dashboard door duct trim located inside the triangular air duct above the main duct.
8. Remove dashboard door duct trim.
9. Pull passengers seat fully back on its rails.
10. Locate and remove 1x screw on the passengers side trim on the side of the center console.
11. Remove 3x screws holding this same center console side trim on at the right hand side of the glove box surround. (The two lower screw and one located underneath)
12. Remove trim.
13. Undo 10x screws from glove box surround. 4x at top, 2x bottom, 2x right and side at top, and 2x left hand side outer (located behind the dashboard door duct trim).
14. Drop glove box surround down.
15. Remove 2x 1 pin clear electrical plugs from glove box light.
16. Remove 2x 1 pin black electrical plugs from glove box light switch on the right hand side of glove box surround.
17. Remove 1x 2 pin white electrical plug from boot release switch.
18. Pry 2x cable hold down pins from rear of glove box surround.
19. Remove glove box surround.
20. Pry the under dash kick tray down from the right hand side.
21. Remove under dash kick tray by sliding to the right. (Locating pins on left hand side).
22. Remove 1x 2 pin electrical plug from blower motor (red and yellow wires)
23. Untape 2x vacuum lines from underneath the blower fan cover trim.
24. Pull the same 2x vacuum lines from locaters under the same blower fan cover trim.
25. Remove 3x coarse thread screws from the blower fan cover trim. 1x front left hand side behind steal bar, 1x right hand side near foot duct outlet, 1x left hand side at the rear near firewall.
26. Remove blower fan cover trim.
27. Undo 3x long coarse thread screws with large washers from the blower fan motor.
28. Drop blower fan motor assembly down and out.
REFITTING POINTS
1. Make sure the blower fan is located correctly before refitting.
2. Make sure all wiring is reconnected.
3. Refit under dash kick tray via the left hand side pins first and push up on right hand side.
4. Re-tape vacuum hoses to trim.
5. Fit the left hand side of glove box first watching the locating pins, then push the right hand locating pin back in once aligned.
By Guy Robinson.
REMOVAL
1. Open glove box
12. Remove trim.
REFITTING POINTS
By Guy Robinson.
