One place has told me $400 gets me a 2 point camber kit and wheel alignment, someone else suggested that a VZ rear end is the better option however i have no idea where to find one, let alone the cost that will be involved.
The issue is the camber is seriously eating my wheels and needs to be resolved soon.
Anyone got any suggestions?
I can do you a 4 point camber kit for $175 plus postage.
The VY or VZ will do as they have adjustment, but if it is out of the range of adjustment in them you will still need a 2 point kit.
is yours series one or 2?
Mate i had a 2 camber kit put into my VTS2 as i had the same problem, now its all good just get a regular wheel alingment and no problems
eh what does a camber kit consist of? and where do you put it?
i do know what it does though
Camber kit replaces the standard (soft) trailing arm bushes with firmer and adjustable ones. There are two bushes per trailing arm.
series 1 vt, no matter what i do be it a 2 point or 4 point kit ill have to pay a place to put them in.
Can anyone tell me what the difference between a 2 point and 4 point is? Im guessing that one is a better reducer of camber wear then the other?
The brand is Super Pro.
They consist of four adjustable bushes that replace the inner control arm bushes on the rear suspension. They give you toe and camber adjustment. It's not really hard to fit them, just time consuming, as you have to remove the lower control arms to fit them.
Im told even a two point kit can be sure of fixing the camberwear on my very low VT, how much better would the 4 point be?
A 2 point kit is not guaranteed to fix it as it only has one adjustment. Even a 4 point kit is guaranteed, but it is a better option because you have two adjustments on each side.
-Smit
Yeah its what im looking at doing. I have found some VYs and VZs being wrecked, and its very tempting to see if they will put the rear end in. Can anyone tell me exactly what would have to come out of the VY/Z to go in mine?
