Results 1 to 15 of 15
Thread: VY/VZ Senator Front bar on VX calais?
    VX II Calais
    May 2009
    West Sydney
    Default VY/VZ Senator Front bar on VX calais?
    Hi all
    Just want to know if its possible? Is there any aftermarket ones out there?
    Cheers Frank
    5.7L VX II Calais ,Tungsten,Vy SS Rims,Full cream leather,Twin,2.5" Redback Catback,Pacemaker 4 to 1's,5% Tint,Chromed Grille
    GAMBLR's Avatar
    GAMBLR is offline More trouble than u think
    '04 VZ Calais LS1
    Dec 2006
    Whyalla (yawn), South Australia
    haven't seen any to date mate but they make VZ clubby to fit VT/VX, so if you poke around a bit, im sure you'll find someone who does it
    CruznCalais
    [GAMBLR]
    The VZ is here! About time!
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Its possible...just don't do it, it looks as dumb as VN's with VT kits etc...
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    Apr 2008
    i've seen a couple vt/vx's with vy clubby kits, not a fan of them. I'd assume there would be a way to modify the bumper to fit.
    redcv6's Avatar
    redcv6 is offline supercharged intercooled
    vy ss ute, diesel landcruiser 100s, hq panel van
    Aug 2006
    Ringwood
    Quote Originally Posted by minux View Post
    F**kin damn straight. don't do it.
    carless for now
    Feb 2007
    perth,Western Australia
    vt ss s2 6spd
    Sep 2008
    i asked bout a vy front conversion to my vt and this is the answer i got
    I'll happily tell you mate. Don't listen to anyone else on these forums that tells you otherwise, they are wrong. I followed parts of their advice only to be disappointed when things didn't fit properly.
    You will need:
    VY/VZ bumper (prices vary)
    VY/VZ guards (prices vary) and guard liners ($40 each from Holden)
    VY/VZ side indicators (prices vary) with new short wiring harness if using VZ guards ($60 each from Holden)
    VY/VZ bonnet ($500-$600 from Holden, $150 - $300 second hand)
    VY/VZ cowl panel parts (3) (cowl panel part 1, $30, cowl panel part 2 (clips over part 1): $18, cowl panel part 3 seal: $10)
    VY/VZ Headlights to suit your bumper (prices vary)
    VY/VZ front bumper reo bar ($100 from Holden)
    VY/VZ front bumper on VT/VX
    Firstly, the VT/VX reo bar (the big bar you see when you take off the bumper) is different (slightly thicker and much heavier) to the VY/VZ reo bar. To install a VY/VZ bumper on a VT/VX you need to use the VY/VZ reo bar. The VY/VZ reo bar is also mounted slightly differently onto the chasis. The mount holes are exactly 20mm lower than the VT/VX mount holes. You can see for yourself if you look on a VY/VZ car (with the bumper and reo off), you'll even see the higher VT/VX mounts holes on the chasis rail as Holden never bothered to revise the chasis rails.
    So you will need to re-drill the mounts 20mm lower to fit the new VY/VZ reo bar on. Get yourself a good drill as it is very tough to do. Bolt the new reo on and then your VY/VZ bumper will fit.
    VY/VZ bonnet vs VT/VX bonnet
    You will need: VY/VZ bonnet, VY/VZ washer jets (two, $10.50 each), VY/VZ cowl panel (two pieces, costs about $40 total), VY/VZ cowl panel seal ($10) and VY/VZ bonnet hinges ($18 each).
    Just a note, do not use a VY bumper with a VZ bonnet (and vice versa), it won't fit properly. You can also keep your old VT/VX bonnet if you use a VY bumper (as seen in my pictures), there will be a small gap on either side of the VT/VX cowl panel (where the wipers sit) though.
    Bonnet is an easy process. Remove VT/VX bonnet with its hinges and rip off the old cowl panel. Install the new bonnet USING the VY/VZ hinges. VT/VX hinges are different and won't fit properly.
    Cowl panel is a little tricky to figure how on how to install but think of it like a puzzle. If I could figure it out, anyone can. It all clips together basically anyway.
    VY/VZ no longer has washer jets mounted on the bonnet like the VT/VX models. They are now mounted in the cowl panel (they click in). You can even use your existing VT/VX washer hose and cut it to size. You will even have some left over.
    VY/VZ Guards
    Just a quick note, you can use VY guards on a VZ bumper and vice versa (I have VZ guards with my VY Senator front). VY/VZ guards will fit on VT/VX models with small modification. You need to use a hammer and curve each side of your VT/VZ guard reo (shell) very slightly. To see what bit needs curving, stand over your car and try to put on the new guard while looking down inside and you will see the offending piece of metal.
    Two things that will annoy you:
    1. You will need to buy new VY/VZ guard liners from Holden ($40 each) as the old VT/VX liners will not fit the new bumper. You can leave them off but you'll get a lot of dirt stuck in your wheel wells and door hinges.
    2. VZ models use a different side indicator harness. So if you buy VZ guards (fluted or not), your existing side indicator harness will not fit the new VZ indicators. You'll have to cut them off a wreck. New from Holden they are about $60 a side (short harness), I think not. I got them for $20 for a pair from a wreck. For shits and giggles, the same VT/VX part is only $8 a side. Bloody Holden.
    VY/VZ Headlights
    Just learnt that VZ projector headlights, although they look they same as VY projector headlights, they won't fit a VY bumper and vice versa...
    Make sure the VY/VZ headlights you buy are the correct ones to fit the model your VY/VZ bumper is from. They bolt and plug straight in perfectly however, if you go for projector headlights (VY/VZ HSV, VY/VZ Calais, VZ SS etc), you will need to modify your dip switch wiring (inside the steering wheel column surround, indicator/high beam stalk). I can provide a diagram from LS1 forums if needed. If you don't modify your dip switch wiring (I haven't yet), then when you select high beams, your low beams will turn off.
    VY/VZ side skirts will fit your VT/VX without any problems.
    If anyone needs any help, let me know.
    Cheers.
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    ^^ Sounds similar to a post and PM I have made.
    But that really sums it all up. It is possible but to get the right parts out of Holden can be a pain as well.
    I have converted my VX wagon front to a VZ Senator.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    vt ss s2 6spd
    Sep 2008
    Jul 2006
    Quote Originally Posted by GR3GA View Post
    was from a guy that did a vy senator front to his vt on sc
    Actually it was a VY Senator front on a VX Calais mate
    (i'm the guy that PMed you)
    This is how it turned out
    Unfortunately I sold it today for only $8200. Very cheap for a well looked after VX Calais 5.7L.
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    is it just me or is the right hand side of rear bar has more gap than left side? noticed this abit on a few newer kits on older cars.. but none the less thats a nice vx
    VT S2 LS1 -VX S2 SS LS1
    Feb 2010
    IPSWICH
    Quote Originally Posted by 10WVN View Post
    yeah i agree there looks like a slight alignment issue but,hey it happens. still a tidy car
    A pessimist is a man who thinks all woman are bad. An optimist is a man who hopes they are
    Jul 2006
    Yeah, one side of the mount was sagging a couple mm. Someone tapped it in the car park and did the runner which bent the mount slightly.
    ANd I also fixed the alignment of the bonnet.
    98 VT s pac
    Sep 2009
    Hervey Bay, QLD
    Quote Originally Posted by Alister View Post
    gotta love those type of people, good hear its fixed.. just mentioned it cause ive seen it on a few besides yours but i guess they prob have same issue . . mounts not used to a heavier bar?
  15. #15
    Mick1988's Avatar
    Mick1988 is offline W.A. Cruise Moderator
    Too many to list......
    Apr 2008
    Perth, Western Australia
    Swapping to an entire VY front end would look nice, but a VY bar modified to fit a VX font end would be horrid.. Don't spoil your car.
    VX2 Executive Sedan - 3.8L Auto (for now)
    VT SS Sedan - Supercharged V6 Auto (Genuine L67 SS)
    VN SS Sedan - 5.0L 5 Speed Manual (Currently Balga spec waiting for panel and paint)
  1. [SA] WTB. VR/VS senator/ clubby front bar
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 02-05-2009, 11:32 AM
  2. Vr/s Senator Front Bar + Grill *genuine* / Vt Calais Front Bar + Chrome Grilles
    By petezor in forum Parts And Other Items For Sale
    Last Post: 02-02-2008, 11:42 AM
  3. VY Senator front bar for a VX
    By VicVXBerlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2007, 10:03 PM
  4. VR Senator front Bar to Fit VR Accliam
    By rickneb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-02-2007, 08:40 PM
  5. vn senator front bar
    By todd_vn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-08-2006, 07:55 PM
