Results 1 to 12 of 12
Thread: What type VT Series 2 front disc's to get.
    VT S2 wagon Berlina
    Dec 2008
    Default What type VT Series 2 front disc's to get.
    Hi all.
    I have no modifications on my wagon.
    Went to get the front brakes machined and they were already undersize.
    I only use the car for work and around Adelaide so dont need performance parts. Only looking for a good set of front disc's. Seen some on ebay for $99. Not sure if they are any good.
    Ultra tune wanted to charge me $499 for 2 new disc's and a fluid flush. Cant afford that.
    Just need a good brand.
    Thanks
    Darren
    andyos's Avatar
    andyos is offline Ozzie 98 Clubby
    98 VT CLUBSPORT 5.0L
    Jun 2008
    Wodonga Victoria
    Well i would either go new standard set of front rotors which should be the cheapest option (plenty on ebay) if you are not looking at performance,heard RDA or DBA are good brands. I just fitted a set of slotted DBA rotors on mine and they are great and only about $30 or so bucks more than standard rotors.You will also need new brake pads if you are getting new rotors.You could also look at doing it yourself if you have a bit of mech know how because there are a few guides on this forum with pics to help you.....
    I got my front DBA slotted rotors for $105 each(discounted) then pads cost me about $75 bucks and i had them fitted for $60 dollars. Hope this helps...
    VT S2 wagon Berlina
    Dec 2008
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    +1 For DBA Slotted rotors, got them all round on the VT and it has eliminated the awful VT brake shudder.
    Dont bother with cheap rotors, get either RDA or DBA. Then decide if you can afford or want Slotter or standard.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    jazza15 is offline Jarryd
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    While we are on the topic of cheap rotor replacement, what does everyone think about getting fairly new (used) rotors from the wreckers etc.
    At $20 per rotor and I've seen them, no lip at all, it would be a very cost effective solution.
    Opinions, facts, anyone?
    VT V8 Calais
    Mar 2007
    You would probably want to factor in machining them before you put them on your car. They may look good but who knows when you brake with them for the first time?
    50LTRv8
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    They would probably be Ok if yo need to save some money. Put them on and if they shake get get them machined... which will then cost you more money.
    carless for now
    Feb 2007
    perth,Western Australia
    how do the vx r8's slotted discs and calipers compare to the dba slotted discs and calipers??
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    Quote Originally Posted by greenacc View Post
    How much more money compared to buying new ones? $80 at the worst. $40 for a pair of rotors and I don't know, $20 per rotor machined by some overcharging franchise?
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by jazza15 View Post
    Last time we got rotors machine it was $45 a rotor. It really isnt viable to machine rotors these days.
    1999 VT II S
    Jun 2008
    Eltham North, VIC
    So i guess it is only viable to buy used rotors if you know they are not warped.
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Correct, also machining warped rotors will not fix them. Once they are warped they are ****ed,. Machiniing will keep them flat till the next heavy breaking and the effects will be back.
  1. [NSW] VN V6 Disc's and Pads, 1 year old + Calipers.
    By mischa in forum Parts And Other Items For Sale
    Last Post: 02-01-2009, 10:13 PM
  2. HSV Front Bumper For Series III VS
    By Robbo VS3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-11-2008, 02:53 PM
  3. Vn Front Disc's Fit VR?
    By Daro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-05-2006, 05:18 PM
  4. Vx Series 2 Vz Front.
    By sparkles_vp in forum VT - VX - VU - WH - V2
    Last Post: 25-11-2005, 10:37 PM
