Anyone willing to help???
Hi guys, this is my first post and it has to start with a problem. I try looking in the other other posts but to no success but if i'm wrong i'll apoligise in advance.
Ok, the problem I am faced with is that my cruise control refuses to work! It does not light up or do anything. This has only happened since I had a major service done a month ago. I just thought it was just a fuse, so I checked it and the fuse was fine. According to the fuse panel other components run on the same fuse but all other accessories work. Unless i'm wrong!
I also tried checking with the system check (dash lights) and cruise is lit up but when I put it into drive it does not, no cruise active or anything happens. I did also check wiring to stalk and to the pedal but still to no success.
Hope someone can shed some light on the subject and hope it's something simple to resolve.
Cheers in advance for any help given.
Ray
Hey Ray, If the problem only appeared after you had the service, I personally would go back to the service joint and ask them what they did that could bring on the problem. It's more than likely something simple, and they may be able to go righr to the ares where the fault is, hopefully!....just a thought, did they adjust the brake switch? as that cancels the cruise when the brake is applied.
Pablo
I did contact them but they said internal componants were not touched as the engine was the only item getting serviced. All they did was change the oil, air filter, oil filter, spark plugs, injection flush, replaced the water pump, water coolent, top-up other levels. All in all $700 then I get a nice surprise, my cruise control don't work!
Just thinking about what you said, could it be a faulty brake switch or could it be the stalk itself but indicators work fine?
People have reported before that blown brake bulbs can stop the cruise working. Have a look to see if all your brake lights are working...
Brake lights work fine mate. Im confused!
Happened to me in my VX. The CRUISE globe was blown in the dash compartment. Try replacing that and see how you go.
If I do a test, hold down trip button and down/up buttons and turn key all lights on dash light up including the cruise sign. So im guessing by doing that the bulb has not blown.
Got the same problem with my VT m8, one day me cruise worked then the next day it doesnt.I can turn it on while in the accessories spot but as soon as the car is primed for kick over it goes off and won't turn back on.I replaced the indicator/cruise arm and still there.so any info on this would be great.Gunna have a sus around today while i replace me water pump ; )
Also check my ride,sitting on HSV R8 19's
" And on the Seventh day ,GOD created Commodores!!!! "
At least i'm not alone on this... If you solve it, let me know mate.
I fixed the CC, i followed the cruise cable the the unit and found that the plug slipped off! Anyway thanks to the guys that helped.
Yeah my VT SS has the same problem, it will blow the fuse in the panel, ive tested with the multimeter and cant find any shorts...so next stop will have to be the Auto Elect
