Results 1 to 11 of 11
Thread: Jumps out of gear. Why???
    Ray De Man's Avatar
    Ray De Man is offline Donating Member
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Default Jumps out of gear. Why???
    Hi, just wondering what this problem could be. When driving down the freeway at a steady 80kph or going over speed humps, my auto gearbox jumps out of gear then reconnects after a brief 2 seconds. I have also noticed it slips between gear changes but this does not happen everytime.
    I had it checked by a gearbox guy and he said nothing is wrong, the ecu is not showing any faults.
    Could it be a worn clutch? Engine has done 170+k's
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Ok, alittle more info on the subject. It does it more when the engine is at normal running temp then it does when its cold.
    Someone please help!!!
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    bf xr6 daily, vl project, wb ute project
    Aug 2008
    QLD
    Jun 2005
    is it manual?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Let's disregard the transmission specialist for a second. Too many "mechanics" these days are stuffed if a computer can't diagnose a problem for them.
    Have you checked the fluid level with the engine at operating temperature? The correct procedure is to warm the engine to operating temperature, then shift it through all gear positions, then place it in Park. Switch off the engine and, within ten seconds of switching off, check the oil level. You will probably need an assistant for this procedure.
    Have you checked the colour and condition of the trans fluid? What colour is it - bright red, or darker, almost brown and smells burnt?
    Does the transmission act normally otherwise - change up and down correctly, or are changes slurred (slow and with slight increase in revs between changes?)
    Is the transmission silent or are there noises in specific gears?
    Have you checked to ensure that your transmission selector is correctly adjusted?
    If you can provide some answers to these questions, somebody might be able to come up with some answers for you.
    vt 3.8 ltz
    Aug 2008
    as you said coming out of gear meanu got error 73 - something pressure control valve
    Ray De Man's Avatar
    HBD VZ SV6
    Feb 2009
    Melbourne, Vic
    Ok I have tried what you said and the results are...
    Fluid level is fine, showing on max.
    The colour is light brown, has no real smell, just smells like gearbox oil to me.
    Its starting to slip or hold in gear with revs up. In other words it sometimes gets stuck in gear before it changes down so revs are up. After approx 3 secs it will find the correct gear.
    There is some noise but can't tell if its from the gearbox, diff or tyres. I only hear it around 40kmh upwards.
    I have no idea how to adjust the selector, I only mainly use "D", don't normally use the 123 gears.
    When I did the service the guy said he changed the filter, gearbox oil and tightened something. This was done 2 months ago, don't think gearbox has ever been serviced.
    For the other guys, this is a 4spd auto.
    Hope this info helps.
    vs
    May 2009
    you actually need to check the fluid level while the vehicle is in park and engine is still running, take it for a drive around the block first, come back let it idle for a few minutes then check your auto fluid level, find out what type of fluid the mechanic used in it when it was serviced as the specified oil is DEXRON III
  1. Redline 1st gear & 2nd gear...weird
    By Jamie_87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 09:02 PM
  2. 3rd and 4th gear gear box vn ss
    By CitricAcidVN in forum V8 Development and Modification
    Last Post: 12-12-2008, 04:17 PM
  3. gear box
    By Aryashahin in forum VY Holden Commodore (2002 - 2004)
    Last Post: 21-12-2006, 10:07 AM
  4. 4th gear O/D 4th gear not working in vr
    By nathsvrbt1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 12:17 PM
  5. UK Top Gear and Fifth Gear Episodes
    By oblong in forum General
    Last Post: 25-02-2005, 09:34 AM
