Originally Posted by
holdenvtman1123
Is My BCM Broken?
The drivers electric window will not go up or down. I have applied power directly to the window motor wires and the window will go up and down. I have purchased a new console electric switch. I have replaced the relay under the steering wheel. Fuses are OK. I replaced the wires from the window motor to the body connection plug. I do hear a relay type clicking coming from the BCM when you attempt to use window switch.
Im not sure how much it is to buy new. i always prefer new parts. I own a VT 98 Berlina. it has the LUX or HIGH level of BCM. If someone has had this problem before or if this sounds familiar let me know.
