Results 1 to 7 of 7
Thread: VT Front Headrests
    Vn Exec
    Mar 2009
    Default VT Front Headrests
    Hi, i have a mate who decided at some point for god knows what reason to put the headrests back in his front seats in his S/c l67 vt s pack, Now they don't come out, im assuming due to the grooves in the headrests "legs" Anyone have any idea how these would come out? or what can be done.....
    **EDIT**
    Sorry he put the headrests in the seats the wrong way around (so the headrest is on a backwards angle)
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    There is a little button on one of the legs which you push inwards & then you are able to pull it all the way out....
    It's on the inside of the leg... Hope that helps!
    Vn Exec
    Mar 2009
    nope, doesn't work because the headrests are in backwards.. i don't know if they are stuck or not.
    1998 VT Acclaim S1
    Feb 2008
    If its shoved in the wrong way with brute force, it'll probably take a bit more brute force to get it back out again
    Vn Exec
    Mar 2009
    problem is they "slid right in" easily enough, but no budging when u try to get it out
    VTS5's Avatar
    VTS5 is offline TechJunkie
    '97 VT Spack 5 Speed
    Jul 2005
    Sth.East\Melb
    Take the plastic back cover off,tap'em out get four plastic clips to put the covers back on again.
    HX Kingswood, VT Berlina
    May 2009
    i had to do this recently
    have to jump in the backseat and on the one without the button there is a little hole on the inside. now u have to put a pin or very small screwdriver into it and lift the headrest up
  1. How do you remove the front headrests?
    By Azkatro in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 03-03-2012, 02:41 PM
  2. VT Front Headrests
    By Randy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-03-2011, 10:56 PM
  3. headrests
    By linejockey in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-08-2008, 11:21 PM
  4. vr or vs headrests will the fir vl?
    By lil_oneblue in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2007, 09:01 PM
  5. how do you remove the headrests from the vl front seats??
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-01-2007, 08:28 PM
